Simple routing or configuration problem....I think
Hello all,
I have two 2600's that are having an unusual problem.
I can ping from Router A to Router B, & but I can't do any
TCP i.e. Telnet, SSH, Traceroute, etc
Router A
interface Multilink1
ip directed-broadcast
ip nat outside
no cdp enable
ppp multilink
multilink load-threshold 2 either
multilink-group 1
interface Serial0/0
ip unnumbered Multilink1
encapsulation ppp
no ip mroute-cache
no fair-queue
service-module t1 clock source internal
ppp multilink
multilink-group 1
interface Serial0/1
encapsulation ppp
no ip mroute-cache
no fair-queue
ppp multilink
multilink-group 1
From Router B I can do everything using TCP
Router B
ip address 192.168.1.2 255.255.255.0
ip nat outside
no cdp enable
ppp multilink
multilink-group 1
interface Serial0/0
encapsulation ppp
no ip mroute-cache
no fair-queue
ppp multilink
multilink-group 1
interface Serial0/1
encapsulation ppp
no ip mroute-cache
no fair-queue
ppp multilink
multilink-group 1
Both routers are identical
IOS (tm) C2600 Software (C2600-IS-M), Version 12.0(5)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Tue 17-Aug-99 14:39 by cmong
Image text-base: 0x80008088, data-base: 0x80B5E15C
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Rhapsody@FIC uptime is 1 week, 20 hours, 21 minutes
System image file is "flash:c2600-is-mz.120-5.T1"
cisco 2610 (MPC860) processor (revision 0x202) with 32768K/8192K bytes of memory.
Processor board ID JAD03342330 (2663084462)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Does anyone have a clue as to what is going on?
I am just trying to telnet from 192.168.1 to 192.168.1.2 & can't seem to get there.
Thanks in advance
Rod
1 REPLY
Re: Simple routing or configuration problem....I think
I assume you tried with IP only to eliminate DNS as an issue. You have NAT enabled. Can you telnet without the NAT? Is the access-list configured properly?
Let us know.
Steve
82
