Simple routing or configuration problem....I think
Hello all,
I have two 2600's that are having an unusual problem.
I can ping from Router A to Router B, & but I can't do any
TCP i.e. Telnet, SSH, Traceroute, etc
Router A
interface Multilink1
ip directed-broadcast
ip nat outside
no cdp enable
ppp multilink
multilink load-threshold 2 either
multilink-group 1
interface Serial0/0
ip unnumbered Multilink1
encapsulation ppp
no ip mroute-cache
no fair-queue
service-module t1 clock source internal
ppp multilink
multilink-group 1
interface Serial0/1
encapsulation ppp
no ip mroute-cache
no fair-queue
ppp multilink
multilink-group 1
From Router B I can do everything using TCP
Router B
ip address 192.168.1.2 255.255.255.0
ip nat outside
no cdp enable
ppp multilink
multilink-group 1
interface Serial0/0
encapsulation ppp
no ip mroute-cache
no fair-queue
ppp multilink
multilink-group 1
interface Serial0/1
encapsulation ppp
no ip mroute-cache
no fair-queue
ppp multilink
multilink-group 1
Both routers are identical
IOS (tm) C2600 Software (C2600-IS-M), Version 12.0(5)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Tue 17-Aug-99 14:39 by cmong
Image text-base: 0x80008088, data-base: 0x80B5E15C
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Rhapsody@FIC uptime is 1 week, 20 hours, 21 minutes
System image file is "flash:c2600-is-mz.120-5.T1"
cisco 2610 (MPC860) processor (revision 0x202) with 32768K/8192K bytes of memory.
Processor board ID JAD03342330 (2663084462)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Does anyone have a clue as to what is going on?
I am just trying to telnet from 192.168.1 to 192.168.1.2 & can't seem to get there.
Thanks in advance
Rod
Re: Simple routing or configuration problem....I think
I'm not quit sure, because there is only the interface config, but I believe it has to do with the NAT. How could it be that you applie "ip nat outside" on both
multilink interfaces?
So, NAT takes normaly only place from inside to outside. Ceck your NAT
configuration or remove it for testing.
kind regards
Ulrich Marzoli
www.netaid.de
Is there perhaps 'no ip routing' in somewhere your config ??
If so configure 'ip routing'
Edwin
67
