Simple Routing Question
I have a 1605r router. I have set it up to exist on a small network. Cable modem to the router and the router goes to a switch. There are 6 machines on the network.
The ISP changed its DNS numbers and I changed those in my router config at the name-server and the dns-server lines respectively. I placed the router back on the network and everything is routing traffic fine to the outside.
One exception. I cannot route traffic back to my network at Branch A. Both network are independant and exist on their own cable modem. There are 2 web servers I need to get to there at Branch A. Does anyone see anything in the config below that is allowing me to pass traffic to everyplace except address's of 24.197.19.xxx? I can't even ping those addresses from the router. Just times out. I can ping everything else just fine. The address of the router is the same address as the ones I cannot ping... I was given several statics from my ISP all on the same network.
Why can I not see my own network at Branch A, but can see the rest of the world fine?
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname
logging rate-limit console 10 except errors
enable secret xxxxx
username xxxx password xxxxx
ip subnet-zero
no ip source-route
no ip finger
ip name-server 209.225.8.42
ip name-server 24.240.141.226
ip dhcp pool DHCPPoolLAN_1
network 192.168.100.0 255.255.255.0
--More—
default-router 192.168.100.1
dns-server 209.225.x.x x.x.141.226
interface Ethernet0
ip address 24.x.x.x x.255.252.0
no ip proxy-arp
ip nat outside
ip rip send version 1 2
ip rip receive version 1 2
no ip route-cache
interface Ethernet1
ip address 192.168.100.1 255.255.255.0
no ip proxy-arp
ip nat inside
no ip route-cache
router rip
--More—
no ip route-cache
router rip
network 24.0.0.0
ip nat inside source list 11 interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 24.197.16.1
no ip http server
access-list 11 permit 192.168.100.0 0.0.0.255
line con 0
exec-timeout 0 0
transport input none
line vty 0 4
exec-timeout 0 0
login local
end
Bryan
1 REPLY
VIP Purple
Re: Simple Routing Question
Hello Bryan,
can you post the output of the command:
show ip route
GP
70
