06-08-2006 09:32 AM - edited 03-03-2019 03:34 AM
I'm pretty sure this is a simple problem whose resolution I am overlooking. I just added a new VLAN to a 6513. VLAN 241 shows as active and looks no different from any other VLAN when I execute show vlan on the switch. The correct ports are shown in the VLAN and when I use show port 6/1, the port shows as connected. The VLAN is 241 and the interface for the VLAN is 10.241.234.1. I can ping the interface from within any router on the network just fine but I can't ping the station's IP address on the other side of port 6/1. The VLAN show's up correctly in show ip route. VLAN 241 does show up as allowed on the trunk line. I've compared the VLAN to a working one in the running-config for the switch and the router and nothing appears different. There ar eno access lists being used. Any ideas what I am overlooking here?
06-08-2006 11:31 AM
I was initially thinking that too but I can ping any router on my network. It's only other hosts that I can't reach from the 10.241.0.0 network and none of the hosts outside that subnet can ping in.
06-08-2006 12:55 PM
Any chance of overlapping address ranges with this 241 vlan or have the incorrect netmask on the router or client pcs. Just throwing stuff out there , it appears to be a fairly simple setup and should work . May have to post the msf and mls configs...
06-08-2006 01:56 PM
06-08-2006 03:36 PM
I just noticed that the config for the switch currently only has ports 2-3 in VLAN 241. I changed this as a test. It was originally 1-24.
06-08-2006 01:29 PM
It would make this a lot easier if you can please post the following:
capture the output of extended ping from 6513 to 10.30.100.20 sourcing from 10.241.234.1.
topology
show run from the 6513 with the new vlan 241.
show ip route 10.241.0.0 from the router with an ip address of 10.30.100.20
06-08-2006 03:27 PM
topology
>>I am no longer on site but I can get this tomorrow.
>>This is posted in my last message
>>10.30.100.20 is not a router, it is a server running Checkpoint firewall. I hesitate to mention this because someone will undoubtedly point the finger at that. I have already verified the configuration in Checkpoint. A new network was added for 10.241.0.0 /16 and added to the same rule that allows traffic through for all the other VLANs on the same switch that are not having this problem. I even temporarily set up a 10.241.0.0 /16 -> any rule to make sure that the firewall was not blocking any traffic from that subnet.
06-09-2006 06:05 AM
Are you learning the route to 10.30.100.20 from somewhere? Unless that's true, i don't see a route to from this router to your default gateway?
can you show the output of "show ip route 10.30.100.20"?
interface Vlan1
ip address 10.30.10.201 255.255.0.0
interface Vlan9
ip address 10.9.234.1 255.255.0.0
shutdown
interface Vlan10
ip address 10.10.234.1 255.255.0.0
interface Vlan204
ip address 10.204.234.1 255.255.0.0
interface Vlan211
ip address 10.211.234.1 255.255.0.0
shutdown
interface Vlan224
ip address 10.224.234.1 255.255.0.0
interface Vlan241
ip address 10.241.234.1 255.255.0.0
router eigrp 100
network 10.9.0.0 0.0.255.255
network 10.10.0.0 0.0.255.255
network 10.30.0.0 0.0.255.255
network 10.204.0.0 0.0.255.255
network 10.211.0.0 0.0.255.255
network 10.224.0.0 0.0.255.255
network 10.241.0.0 0.0.255.255
network 10.0.0.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 10.30.100.20
06-09-2006 08:34 AM
10.30.100.20 is the default route.
show ip route 10.30.100.20:
Routing entry for 10.30.0.0/16
Known via "connected", distance 0, metric 0 (connected, via interface)
Redistributing via eigrp 100
Routing Descriptor Blocks:
* directly connected, via Vlan1
Route metric is 0, traffic share count is 1
06-09-2006 10:51 AM
sorry..i mis-read the config...da~
anyway.. couple questions:
Can the Checkpoint firewall ( 10.30.100.20 ) ping the workstations behind the other VLANs? (e.g. Vlan10, etc)
Can you check the route table of Checkpoint and make sure that it's forwarding the packet destined to 10.241/16 to 10.30.10.201?
Eric
06-08-2006 03:16 PM
I didn't look at the configs but I had a quick thought. You don't have any left over acls from when you used this for your laptop still running on the port by any chance? That might explain the blocked traffic.
06-08-2006 03:29 PM
>>I wasn't running any access-lists previously. There aren't any access-lists configured any where actually.
