Singapore: AS5300 | analog dial in
snitram
we have problems in Singapore to dial in analogous over
the public network. The modems does tain up - but they do
not come to an end. Locking down to V34 did not help.
Disabling compression did not help.
We use 2.9.4.0 MICA firmware.
The modemcap is the following:
&F&D2S54=16584S0=0S29=12S21=0S62=8S63=3S34=18000S40=10S10=50
I even tried to dial out on the AS5300 and dial in on an other modem of the very same AS5300. If I call through the pulic telco network in Singapore,
I will not have connection. On the other hand if I call internally - without the pulic telco network in Singapore -, everything works fine.
Any ideas? Any suggestions concernig a "better" modemcap or better client dial in settings for Singapore public telco network?
Best regards, Snitram
9 Replies 9
makchitale
Level 6
Level 6
When you say you are calling internally, does it mean two ports on the controller card are connected back to back (with T1 cross-over cable) and we are directing a call out of one into the other? If the call thru the telco switch is failing then maybe we have excessive noise on the line , does "show controller e1" show any errors?....Listening on the client modem end, does the trainup sound appear that both the modems (client & as5300) are exchanging tones or is it just that both ends are sending the tones but are not hearing each other (cross path)?
1)Has this ever worked before or is it a new install?
2)What type of signalling do we have, PRI or E1-R2?
3) What IOS image do we have on the as5300?
4)Are we testing with a non v.92 or v92 modems
Recommended modemcap for 2.9.4.0 in a V.92/V.44 application:
if using 12.2(2)XB6+ or 12.2(11+)T & higher (recommended):
&F&D2S0=0S62=8S34=18000S40=10S10=50
If using earlier IOS (not recommended): &F&D2S54=16584S0=0S29=12S21=15S62=8S63=3S34=18000S40=10S10=50
Recommended modemcap for 2.9.4.0 in a non-V.92 application:
&F&D2S0=0S29=6S21=3S34=18000S40=10S10=50
Thanks, Mak.
Hello Mak,
thank you very much. Internally - the AS5300 is connected to an E1 Interface
of a Hicom PBX. Therefore I mean internally = without the public telco network.
Show controller e1 does not show up any error.
The trainup sound appear. Everything seems to be correct.
1.) Yes, it is a new install.
2.) How can I find it out?
AS5300# sh run
controller E1 1
clock source line primary
pri-group timeslots 1-31
AS5300#sh controllers e1 1
E1 1 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
Version info of Slot 0: HW: 4, Firmware: 4, PLD Rev: 0
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x43,
Board Hardware Version 1.32, Item Number 73-2218-5,
Board Revision B32, Serial Number 10082309,
PLD/ISP Version 0.0, Manufacture Date 24-Oct-1998.
Framing is CRC4, Line Code is HDB3, Clock Source is Line Primary.
Data in current interval (166 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 1:
Data in Interval 2:
Total Data (last 2 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
3.) 12.1(3) - but I have only 64 MB RAM
4.) At the moment with non-V.92, because I use one line to dial out.
This is a PRI line, can you please send the following debug outputs for a single call into the as5300 (with msec timestamps):
conf term
service time debug date msec
deb isdn q931/ deb modem / deb modem csm / deb ppp nego
Also can you try moving the PRI to another port if you have one spare...
Thanks, Mak.
Hello Mak,
annexed three times dial in.
modemcap entry MYCAP:MSC=&F&D2S0=0S29=6S21=3S34=18000S40=10S10=50
dial in externally -> no connection
Many thanks and best regards, Snitram
BTW: Do you have information concerning CSCOdv02248?
I cannot access this bug.
*Jan 1 00:59:07.827: Mica Modem(1/0): Rcvd Dial String(XXXXXXX)
*Jan 1 00:59:07.827: CSM_PROC_IDLE: CSM_EVENT_MODEM_OFFHOOK at slot 1, port 0
*Jan 1 00:59:07.827: csm_get_signaling_channel dchan_index=24906,next_index=0
*Jan 1 00:59:07.827: csm_get_signaling_channel dchan_info=61B718D0
*Jan 1 00:59:07.827: CSM_PROC_OC3_COLLECT_ALL_DIGIT: CSM_EVENT_GET_ALL_DIGITS at slot 1, port 0
*Jan 1 00:59:07.827: CSM_PROC_OC3_COLLECT_ALL_DIGIT: called party num: (XXXXXXX) at slot 1, port 0
*Jan 1 00:59:07.827: csm_get_signaling_channel dchan_index=24893,next_index=0
*Jan 1 00:59:07.831: ISDN Se1:15: TX -> SETUP pd = 8 callref = 0x0009
*Jan 1 00:59:07.831: Bearer Capability i = 0x8090A3
*Jan 1 00:59:07.831: Channel ID i = 0xA9839F
*Jan 1 00:59:07.831: Calling Party Number i = 0x81, 'ZZZZZZZ', Plan:ISDN, Type:Unknown
*Jan 1 00:59:07.831: Called Party Number i = 0x81, 'XXXXXXX', Plan:ISDN, Type:Unknown
*Jan 1 00:59:07.907: ISDN Se1:15: RX <- SETUP_ACK pd = 8 callref = 0x8009
*Jan 1 00:59:07.907: Channel ID i = 0xA9839F
*Jan 1 00:59:07.907: EVENT_FROM_ISDN::dchan_idb=0x61B718D0, call_id=0x800A, ces=0x1
bchan=0x1E, event=0x3, cause=0x0
*Jan 1 00:59:07.907: EVENT_FROM_ISDN:(800A): DEV_CALL_PROC at slot 1 and port 0
*Jan 1 00:59:07.907: CSM_PROC_OC4_DIALING: CSM_EVENT_ISDN_BCHAN_ASSIGNED at slot 1, port 0
*Jan 1 00:59:07.907: Enter csm_connect_pri_vdev function
*Jan 1 00:59:07.907: csm_connect_pri_vdev:tdm_allocate_bp_ts() call. BP TS allocated at bp_stream0, bp_Ch15,vdev_common 0x614CC548
*Jan 1 00:59:07.907: Mica Modem(1/0): Configure(0x1 = 0x1)
*Jan 1 00:59:07.907: Mica Modem(1/0): Configure(0x23 = 0x0)
*Jan 1 00:59:07.907: Mica Modem(1/0): Call Setup
*Jan 1 00:59:08.067: Mica Modem(1/0): State Transition to Call Setup
*Jan 1 00:59:15.355: ISDN Se1:15: RX <- SETUP pd = 8 callref = 0x0018
*Jan 1 00:59:15.359: Bearer Capability i = 0x9090A3
*Jan 1 00:59:15.359: Channel ID i = 0xA98399
*Jan 1 00:59:15.359: Facility i = 0x91A12102027E2202010F30180201010A0101A107A0058003363033A207A0058003363033
*Jan 1 00:59:15.359: - ETSI Supplementary Service, Invoke, Unsupported operation
*Jan 1 00:59:15.359: Progress Ind i = 0x8083 - Origination address is non-ISDN
*Jan 1 00:59:15.359: Progress Ind i = 0x8088 - In-band info or appropriate now available
*Jan 1 00:59:15.359: Calling Party Number i = 0x00C3, Plan:Unknown, Type:Unknown
*Jan 1 00:59:15.359: Called Party Number i = 0x89, 'YYYYYYY', Plan:Private, Type:Unknown
*Jan 1 00:59:15.363: VDEV_ALLOCATE: 2/2 is allocated
*Jan 1 00:59:15.363: ISDN Se1:15: TX -> CALL_PROC pd = 8 callref = 0x8018
*Jan 1 00:59:15.363: Channel ID i = 0xA98399
*Jan 1 00:59:15.367: EVENT_FROM_ISDN::dchan_idb=0x61B718D0, call_id=0x8, ces=0x0
bchan=0x18, event=0x1, cause=0x0
*Jan 1 00:59:15.367: EVENT_FROM_ISDN:(0008): DEV_INCALL at slot 2 and port 2
*Jan 1 00:59:15.367: CSM_PROC_IDLE: CSM_EVENT_ISDN_CALL at slot 2, port 2
*Jan 1 00:59:15.367: Mica Modem(2/2): Configure(0x1 = 0x0)
*Jan 1 00:59:15.367: Mica Modem(2/2): Configure(0x23 = 0x0)
*Jan 1 00:59:15.367: Mica Modem(2/2): Call Setup
*Jan 1 00:59:15.367: Enter csm_connect_pri_vdev function
*Jan 1 00:59:15.367: csm_connect_pri_vdev:tdm_allocate_bp_ts() call. BP TS allocated at bp_stream0, bp_Ch16,vdev_common 0x6158ED5C
*Jan 1 00:59:15.367: ISDN Se1:15: TX -> ALERTING pd = 8 callref = 0x8018
*Jan 1 00:59:15.515: Mica Modem(2/2): State Transition to Call Setup
*Jan 1 00:59:15.515: Mica Modem(2/2): Went offhook
*Jan 1 00:59:15.515: CSM_PROC_IC2_RING: CSM_EVENT_MODEM_OFFHOOK at slot 2, port 2
*Jan 1 00:59:15.515: ISDN Se1:15: TX -> CONNECT pd = 8 callref = 0x8018
*Jan 1 00:59:15.599: ISDN Se1:15: RX <- CONNECT_ACK pd = 8 callref = 0x0018
*Jan 1 00:59:15.599: ISDN Se1:15: CALL_PROGRESS: CALL_CONNECTED call id 0x8, bchan -1, dsl 0
*Jan 1 00:59:15.599: EVENT_FROM_ISDN::dchan_idb=0x61B718D0, call_id=0x8, ces=0x0
bchan=0x18, event=0x4, cause=0x0
*Jan 1 00:59:15.599: EVENT_FROM_ISDN:(0008): DEV_CONNECTED at slot 2 and port 2
*Jan 1 00:59:15.603: CSM_PROC_IC6_WAIT_FOR_CONNECT: CSM_EVENT_ISDN_CONNECTED at slot 2, port 2
*Jan 1 00:59:15.603: Mica Modem(2/2): Link Initiate
*Jan 1 00:59:15 UTC: %ISDN-6-CONNECT: Interface Serial1:24 is now connected to N/A N/A
*Jan 1 00:59:15.695: Mica Modem(2/2): State Transition to Connect
*Jan 1 00:59:16.791: ISDN Se1:15: RX <- ALERTING pd = 8 callref = 0x8009
*Jan 1 00:59:16.795: Progress Ind i = 0x8081 - Call not end-to-end ISDN, may have in-band info
*Jan 1 00:59:16.795: EVENT_FROM_ISDN::dchan_idb=0x61B718D0, call_id=0x800A, ces=0x1
bchan=0x1E, event=0x10, cause=0x0
*Jan 1 00:59:17.199: ISDN Se1:15: RX <- CONNECT pd = 8 callref = 0x8009
*Jan 1 00:59:17.203: EVENT_FROM_ISDN::dchan_idb=0x61B718D0, call_id=0x800A, ces=0x1
bchan=0x1E, event=0x4, cause=0x0
*Jan 1 00:59:17.203: EVENT_FROM_ISDN:(800A): DEV_CONNECTED at slot 1 and port 0
*Jan 1 00:59:17.203: CSM_PROC_OC5_WAIT_FOR_CARRIER: CSM_EVENT_ISDN_CONNECTED at slot 1, port 0
*Jan 1 00:59:17.203: Mica Modem(1/0): Link Initiate
*Jan 1 00:59:17 UTC: %ISDN-6-CONNECT: Interface Serial1:30 is now connected to XXXXXXX
*Jan 1 00:59:17.203: ISDN Se1:15: TX -> CONNECT_ACK pd = 8 callref = 0x0009
*Jan 1 00:59:17.311: Mica Modem(1/0): State Transition to Connect
*Jan 1 00:59:20.139: Mica Modem(2/2): State Transition to Link
*Jan 1 00:59:20.675: Mica Modem(1/0): State Transition to Link
*Jan 1 00:59:34.307: Mica Modem(2/2): State Transition to Trainup
*Jan 1 00:59:34.603: Mica Modem(1/0): State Transition to Trainup
*Jan 1 01:00:19.035: Mica Modem(2/2): State Transition to Terminating
*Jan 1 01:00:19.635: Mica Modem(2/2): State Transition to Idle
*Jan 1 01:00:19.635: Mica Modem(2/2): Went onhook
*Jan 1 01:00:19.635: CSM_PROC_IC7_OC6_CONNECTED: CSM_EVENT_MODEM_ONHOOK at slot 2, port 2
*Jan 1 01:00:19.635: Enter csm_enter_idle_state
*Jan 1 01:00:19.635: VDEV_DEALLOCATE: slot 2 and port 2 is deallocated
*Jan 1 01:00:19 UTC: %ISDN-6-DISCONNECT: Interface Serial1:24 disconnected from unknown , call lasted 64 seconds
*Jan 1 01:00:19.639: ISDN Se1:15: TX -> DISCONNECT pd = 8 callref = 0x8018
*Jan 1 01:00:19.639: Cause i = 0x8090 - Normal call clearing
*Jan 1 01:00:20.295: ISDN Se1:15: RX <- RELEASE pd = 8 callref = 0x0018
*Jan 1 01:00:20.295: Cause i = 0x8090 - Normal call clearing
*Jan 1 01:00:20.299: ISDN Se1:15: TX -> RELEASE_COMP pd = 8 callref = 0x8018
*Jan 1 01:00:20 UTC: %LINK-3-UPDOWN: Interface Serial1:24, changed state to down
*Jan 1 01:00:20.595: Mica Modem(1/0): State Transition to Terminating
*Jan 1 01:00:20.903: ISDN Se1:15: RX <- DISCONNECT pd = 8 callref = 0x8009
*Jan 1 01:00:20.903: Cause i = 0x8090 - Normal call clearing
*Jan 1 01:00:20 UTC: %ISDN-6-DISCONNECT: Interface Serial1:30 disconnected from XXXXXXX , call lasted 63 seconds
*Jan 1 01:00:20.903: EVENT_FROM_ISDN::dchan_idb=0x61B718D0, call_id=0x800A, ces=0x1
bchan=0x1E, event=0x0, cause=0x10
*Jan 1 01:00:20.903: EVENT_FROM_ISDN:(800A): DEV_IDLE at slot 1 and port 0
*Jan 1 01:00:20.907: CSM_PROC_IC7_OC6_CONNECTED: CSM_EVENT_ISDN_DISCONNECTED at slot 1, port 0
*Jan 1 01:00:20.907: Mica Modem(1/0): Link Terminate(0x6)
*Jan 1 01:00:20.907: Enter csm_enter_disconnecting_state
*Jan 1 01:00:20.907: ISDN Se1:15: TX -> RELEASE pd = 8 callref = 0x0009
*Jan 1 01:00:20.955: Mica Modem(1/0): State Transition to Idle
*Jan 1 01:00:20.955: Mica Modem(1/0): Went onhook
*Jan 1 01:00:20.955: CSM_PROC_IC8_OC8_DISCONNECTING: CSM_EVENT_MODEM_ONHOOK at slot 1, port 0
*Jan 1 01:00:20.955: Enter csm_enter_idle_state
*Jan 1 01:00:20.995: ISDN Se1:15: RX <- RELEASE_COMP pd = 8 callref = 0x8009
*Jan 1 01:00:20.995: Cause i = 0x8090 - Normal call clearing
*Jan 1 01:00:23.395: CSM_PROC_IDLE: CSM_EVENT_DSX0_DISCONN_TIMEOUT at slot 1, port 0
Hello Mak,
dial in internally -> CONNECT 31200 /V.42/V.42bis
*Jan 1 01:00:31.399: Mica Modem(1/0): Rcvd Dial String(YYYYYYY)
*Jan 1 01:00:31.399: CSM_PROC_IDLE: CSM_EVENT_MODEM_OFFHOOK at slot 1, port 0
*Jan 1 01:00:31.399: csm_get_signaling_channel dchan_index=24906,next_index=0
*Jan 1 01:00:31.399: csm_get_signaling_channel dchan_info=61B718D0
*Jan 1 01:00:31.399: CSM_PROC_OC3_COLLECT_ALL_DIGIT: CSM_EVENT_GET_ALL_DIGITS at slot 1, port 0
*Jan 1 01:00:31.399: CSM_PROC_OC3_COLLECT_ALL_DIGIT: called party num: (YYYYYYY) at slot 1, port 0
*Jan 1 01:00:31.399: csm_get_signaling_channel dchan_index=24893,next_index=0
*Jan 1 01:00:31.403: ISDN Se1:15: TX -> SETUP pd = 8 callref = 0x000A
*Jan 1 01:00:31.403: Bearer Capability i = 0x8090A3
*Jan 1 01:00:31.403: Channel ID i = 0xA9839F
*Jan 1 01:00:31.403: Calling Party Number i = 0x81, 'ZZZZZZZ', Plan:ISDN, Type:Unknown
*Jan 1 01:00:31.403: Called Party Number i = 0x81, 'YYYYYYY', Plan:ISDN, Type:Unknown
*Jan 1 01:00:31.499: ISDN Se1:15: RX <- SETUP_ACK pd = 8 callref = 0x800A
*Jan 1 01:00:31.503: Channel ID i = 0xA9839F
*Jan 1 01:00:31.503: EVENT_FROM_ISDN::dchan_idb=0x61B718D0, call_id=0x800B, ces=0x1
*Jan 1 01:00:31.503: EVENT_FROM_ISDN:(800B): DEV_CALL_PROC at slot 1 and port 0
*Jan 1 01:00:31.503: CSM_PROC_OC4_DIALING: CSM_EVENT_ISDN_BCHAN_ASSIGNED at slot 1, port 0
*Jan 1 01:00:31.503: Enter csm_connect_pri_vdev function
*Jan 1 01:00:31.503: csm_connect_pri_vdev:tdm_allocate_bp_ts() call. BP TS allocated at bp_stream0, bp_Ch17,vdev_common 0x614CC548
*Jan 1 01:00:31.503: Mica Modem(1/0): Configure(0x1 = 0x1)
*Jan 1 01:00:31.503: Mica Modem(1/0): Configure(0x23 = 0x0)
*Jan 1 01:00:31.503: Mica Modem(1/0): Call Setup
*Jan 1 01:00:31.507: ISDN Se1:15: RX <- SETUP pd = 8 callref = 0x0019
*Jan 1 01:00:31.507: Bearer Capability i = 0x8090A3
*Jan 1 01:00:31.511: Channel ID i = 0xA9839A
*Jan 1 01:00:31.511: Calling Party Number i = 0x0080, 'ZZZZZZZ', Plan:Unknown, Type:Unknown
*Jan 1 01:00:31.511: Called Party Number i = 0x80, 'YYYYYYY', Plan:Unknown, Type:Unknown
*Jan 1 01:00:31.511: VDEV_ALLOCATE: 2/3 is allocated
*Jan 1 01:00:31.515: ISDN Se1:15: TX -> CALL_PROC pd = 8 callref = 0x8019
*Jan 1 01:00:31.515: Channel ID i = 0xA9839A
*Jan 1 01:00:31.515: EVENT_FROM_ISDN::dchan_idb=0x61B718D0, call_id=0x9, ces=0x0
bchan=0x19, event=0x1, cause=0x0
*Jan 1 01:00:31.515: EVENT_FROM_ISDN:(0009): DEV_INCALL at slot 2 and port 3
*Jan 1 01:00:31.515: CSM_PROC_IDLE: CSM_EVENT_ISDN_CALL at slot 2, port 3
*Jan 1 01:00:31.515: Mica Modem(2/3): Configure(0x1 = 0x0)
*Jan 1 01:00:31.515: Mica Modem(2/3): Configure(0x23 = 0x0)
*Jan 1 01:00:31.515: Mica Modem(2/3): Call Setup
*Jan 1 01:00:31.515: Enter csm_connect_pri_vdev function
*Jan 1 01:00:31.515: csm_connect_pri_vdev:tdm_allocate_bp_ts() call. BP TS allocated at bp_stream0, bp_Ch18,vdev_common 0x615907FC
*Jan 1 01:00:31.515: ISDN Se1:15: TX -> ALERTING pd = 8 callref = 0x8019
*Jan 1 01:00:31.599: ISDN Se1:15: RX <- CALL_PROC pd = 8 callref = 0x800A
*Jan 1 01:00:31.599: Channel ID i = 0xA9839F
*Jan 1 01:00:31.631: ISDN Se1:15: RX <- ALERTING pd = 8 callref = 0x800A
*Jan 1 01:00:31.631: EVENT_FROM_ISDN::dchan_idb=0x61B718D0, call_id=0x800B, ces=0x1
*Jan 1 01:00:31.639: Mica Modem(1/0): State Transition to Call Setup
*Jan 1 01:00:31.643: Mica Modem(2/3): State Transition to Call Setup
*Jan 1 01:00:31.643: Mica Modem(2/3): Went offhook
*Jan 1 01:00:31.643: CSM_PROC_IC2_RING: CSM_EVENT_MODEM_OFFHOOK at slot 2, port 3
*Jan 1 01:00:31.647: ISDN Se1:15: TX -> CONNECT pd = 8 callref = 0x8019
*Jan 1 01:00:31.715: ISDN Se1:15: RX <- CONNECT_ACK pd = 8 callref = 0x0019
*Jan 1 01:00:31.719: ISDN Se1:15: CALL_PROGRESS: CALL_CONNECTED call id 0x9, bchan -1, dsl 0
*Jan 1 01:00:31.719: EVENT_FROM_ISDN::dchan_idb=0x61B718D0, call_id=0x9, ces=0x0
bchan=0x19, event=0x4, cause=0x0
*Jan 1 01:00:31.719: EVENT_FROM_ISDN:(0009): DEV_CONNECTED at slot 2 and port 3
*Jan 1 01:00:31.719: CSM_PROC_IC6_WAIT_FOR_CONNECT: CSM_EVENT_ISDN_CONNECTED at slot 2, port 3
*Jan 1 01:00:31.719: Mica Modem(2/3): Link Initiate
*Jan 1 01:00:31 UTC: %ISDN-6-CONNECT: Interface Serial1:25 is now connected to ZZZZZZZ
*Jan 1 01:00:31.735: ISDN Se1:15: RX <- CONNECT pd = 8 callref = 0x800A
*Jan 1 01:00:31.735: EVENT_FROM_ISDN::dchan_idb=0x61B718D0, call_id=0x800B, ces=0x1
*Jan 1 01:00:31.735: EVENT_FROM_ISDN:(800B): DEV_CONNECTED at slot 1 and port 0
*Jan 1 01:00:31.735: CSM_PROC_OC5_WAIT_FOR_CARRIER: CSM_EVENT_ISDN_CONNECTED at slot 1, port 0
*Jan 1 01:00:31.735: Mica Modem(1/0): Link Initiate
*Jan 1 01:00:31 UTC: %ISDN-6-CONNECT: Interface Serial1:30 is now connected to YYYYYYY
*Jan 1 01:00:31.735: ISDN Se1:15: TX -> CONNECT_ACK pd = 8 callref = 0x000A
*Jan 1 01:00:31.819: Mica Modem(1/0): State Transition to Connect
*Jan 1 01:00:31.823: Mica Modem(2/3): State Transition to Connect
*Jan 1 01:00:39.151: Mica Modem(2/3): State Transition to Link
*Jan 1 01:00:39.267: Mica Modem(1/0): State Transition to Link
*Jan 1 01:00:48.095: Mica Modem(2/3): State Transition to Trainup
*Jan 1 01:00:48.151: Mica Modem(1/0): State Transition to Trainup
*Jan 1 01:00:49.831: Mica Modem(1/0): State Transition to EC Negotiating
*Jan 1 01:00:49.835: Mica Modem(2/3): State Transition to EC Negotiating
*Jan 1 01:00:49.955: Mica Modem(2/3): State Transition to Steady State
*Jan 1 01:00:50.011: Mica Modem(1/0): State Transition to Steady State
*Jan 1 01:00:50.391: TTY64: DSR came up
*Jan 1 01:00:50.391: tty64: Modem: IDLE->(unknown)
*Jan 1 01:00:50.391: TTY64: EXEC creation
*Jan 1 01:00:50.391: TTY64: set timer type 10, 30 seconds
*Jan 1 01:01:00.067: TTY64: set timer type 10, 30 seconds
*Jan 1 01:01:01.911: TTY64: create timer type 1, 600 seconds
*Jan 1 01:01:03.447: TTY64: Line reset by "Exec"
*Jan 1 01:01:04.447: TTY64: Modem: (unknown)->HANGUP
*Jan 1 01:01:04.447: TTY64: destroy timer type 0
*Jan 1 01:01:04.447: TTY64: destroy timer type 1 (OK)
*Jan 1 01:01:04.447: TTY64: destroy timer type 3
*Jan 1 01:01:04.447: TTY64: destroy timer type 4
*Jan 1 01:01:04.447: TTY64: destroy timer type 2
*Jan 1 01:01:05.391: TTY64: dropping DTR, hanging up
*Jan 1 01:01:05.391: tty64: Modem: HANGUP->IDLE
*Jan 1 01:01:05.447: Mica Modem(2/3): State Transition to Terminating
*Jan 1 01:01:05.507: Mica Modem(2/3): State Transition to Idle
*Jan 1 01:01:05.507: Mica Modem(2/3): Went onhook
*Jan 1 01:01:05.507: CSM_PROC_IC7_OC6_CONNECTED: CSM_EVENT_MODEM_ONHOOK at slot 2, port 3
*Jan 1 01:01:05.507: Enter csm_enter_idle_state
*Jan 1 01:01:05.507: VDEV_DEALLOCATE: slot 2 and port 3 is deallocated
*Jan 1 01:01:05 UTC: %ISDN-6-DISCONNECT: Interface Serial1:25 disconnected from ZZZZZZZ , call lasted 33 seconds
*Jan 1 01:01:05.511: ISDN Se1:15: TX -> DISCONNECT pd = 8 callref = 0x8019
*Jan 1 01:01:05.511: Cause i = 0x8090 - Normal call clearing
*Jan 1 01:01:05.563: Mica Modem(1/0): State Transition to Steady State Retraining
*Jan 1 01:01:05.595: ISDN Se1:15: RX <- DISCONNECT pd = 8 callref = 0x800A
*Jan 1 01:01:05.595: Cause i = 0x8090 - Normal call clearing
*Jan 1 01:01:05 UTC: %ISDN-6-DISCONNECT: Interface Serial1:30 disconnected from YYYYYYY , call lasted 33 seconds
*Jan 1 01:01:05.595: EVENT_FROM_ISDN::dchan_idb=0x61B718D0, call_id=0x800B, ces=0x1
*Jan 1 01:01:05.595: EVENT_FROM_ISDN:(800B): DEV_IDLE at slot 1 and port 0
*Jan 1 01:01:05.595: CSM_PROC_IC7_OC6_CONNECTED: CSM_EVENT_ISDN_DISCONNECTED at slot 1, port 0
*Jan 1 01:01:05.595: Mica Modem(1/0): Link Terminate(0x6)
*Jan 1 01:01:05.599: Enter csm_enter_disconnecting_state
*Jan 1 01:01:05.599: ISDN Se1:15: TX -> RELEASE pd = 8 callref = 0x000A
*Jan 1 01:01:05.623: Mica Modem(1/0): State Transition to Terminating
*Jan 1 01:01:05.671: ISDN Se1:15: RX <- RELEASE_COMP pd = 8 callref = 0x800A
*Jan 1 01:01:05.671: Cause i = 0x8090 - Normal call clearing
*Jan 1 01:01:05.683: Mica Modem(1/0): State Transition to Idle
*Jan 1 01:01:05.683: Mica Modem(1/0): Went onhook
*Jan 1 01:01:05.683: CSM_PROC_IC8_OC8_DISCONNECTING: CSM_EVENT_MODEM_ONHOOK at slot 1, port 0
*Jan 1 01:01:05.683: Enter csm_enter_idle_state
*Jan 1 01:01:05.687: ISDN Se1:15: RX <- RELEASE pd = 8 callref = 0x0019
*Jan 1 01:01:05.687: ISDN Se1:15: TX -> RELEASE_COMP pd = 8 callref = 0x8019
*Jan 1 01:01:05 UTC: %LINK-3-UPDOWN: Interface Serial1:25, changed state to down
*Jan 1 01:01:07.407: TTY64: restoring DTR
*Jan 1 01:01:07.407: TTY64: autoconfigure probe started
*Jan 1 01:01:09.395: CSM_PROC_IDLE: CSM_EVENT_DSX0_DISCONN_TIMEOUT at slot 1, port 0
Hello Mak,
dial in externally with S54=4 -> CONNECT 4800 /V.42/V.42bis
*Jan 1 01:05:25.235: Mica Modem(1/0): Rcvd Dial String(XXXXXXX)
*Jan 1 01:05:25.235: CSM_PROC_IDLE: CSM_EVENT_MODEM_OFFHOOK at slot 1, port 0
*Jan 1 01:05:25.235: csm_get_signaling_channel dchan_index=24906,next_index=0
*Jan 1 01:05:25.235: csm_get_signaling_channel dchan_info=61B718D0
*Jan 1 01:05:25.235: CSM_PROC_OC3_COLLECT_ALL_DIGIT: CSM_EVENT_GET_ALL_DIGITS at slot 1, port 0
*Jan 1 01:05:25.235: CSM_PROC_OC3_COLLECT_ALL_DIGIT: called party num: (XXXXXXX) at slot 1, port 0
*Jan 1 01:05:25.235: csm_get_signaling_channel dchan_index=24893,next_index=0
*Jan 1 01:05:25.239: ISDN Se1:15: TX -> SETUP pd = 8 callref = 0x000C
*Jan 1 01:05:25.239: Bearer Capability i = 0x8090A3
*Jan 1 01:05:25.239: Channel ID i = 0xA9839F
*Jan 1 01:05:25.239: Calling Party Number i = 0x81, 'ZZZZZZZ', Plan:ISDN, Type:Unknown
*Jan 1 01:05:25.239: Called Party Number i = 0x81, 'XXXXXXX', Plan:ISDN, Type:Unknown
*Jan 1 01:05:25.331: ISDN Se1:15: RX <- SETUP_ACK pd = 8 callref = 0x800C
*Jan 1 01:05:25.331: Channel ID i = 0xA9839F
*Jan 1 01:05:25.331: EVENT_FROM_ISDN::dchan_idb=0x61B718D0, call_id=0x800D, ces=0x1
*Jan 1 01:05:25.331: EVENT_FROM_ISDN:(800D): DEV_CALL_PROC at slot 1 and port 0
*Jan 1 01:05:25.331: CSM_PROC_OC4_DIALING: CSM_EVENT_ISDN_BCHAN_ASSIGNED at slot 1, port 0
*Jan 1 01:05:25.331: Enter csm_connect_pri_vdev function
*Jan 1 01:05:25.331: csm_connect_pri_vdev:tdm_allocate_bp_ts() call. BP TS allocated at bp_stream0, bp_Ch21,vdev_common 0x614CC548
*Jan 1 01:05:25.331: Mica Modem(1/0): Configure(0x1 = 0x1)
*Jan 1 01:05:25.331: Mica Modem(1/0): Configure(0x23 = 0x0)
*Jan 1 01:05:25.335: Mica Modem(1/0): Call Setup
*Jan 1 01:05:25.475: Mica Modem(1/0): State Transition to Call Setup
*Jan 1 01:05:32.435: ISDN Se1:15: RX <- SETUP pd = 8 callref = 0x001B
*Jan 1 01:05:32.435: Bearer Capability i = 0x9090A3
*Jan 1 01:05:32.435: Channel ID i = 0xA9839C
*Jan 1 01:05:32.435: Facility i = 0x91A12102027EA202010F30180201010A0101A107A0058003363033A207A0058003363033
*Jan 1 01:05:32.439: - ETSI Supplementary Service, Invoke, Unsupported operation
*Jan 1 01:05:32.439: Progress Ind i = 0x8083 - Origination address is non-ISDN
*Jan 1 01:05:32.439: Progress Ind i = 0x8088 - In-band info or appropriate now available
*Jan 1 01:05:32.439: Calling Party Number i = 0x00C3, Plan:Unknown, Type:Unknown
*Jan 1 01:05:32.439: Called Party Number i = 0x89, 'YYYYYYY', Plan:Private, Type:Unknown
*Jan 1 01:05:32.439: VDEV_ALLOCATE: 2/5 is allocated
*Jan 1 01:05:32.443: ISDN Se1:15: TX -> CALL_PROC pd = 8 callref = 0x801B
*Jan 1 01:05:32.443: Channel ID i = 0xA9839C
*Jan 1 01:05:32.443: EVENT_FROM_ISDN::dchan_idb=0x61B718D0, call_id=0xB, ces=0x0
bchan=0x1B, event=0x1, cause=0x0
*Jan 1 01:05:32.443: EVENT_FROM_ISDN:(000B): DEV_INCALL at slot 2 and port 5
*Jan 1 01:05:32.443: CSM_PROC_IDLE: CSM_EVENT_ISDN_CALL at slot 2, port 5
*Jan 1 01:05:32.443: Mica Modem(2/5): Configure(0x1 = 0x0)
*Jan 1 01:05:32.443: Mica Modem(2/5): Configure(0x23 = 0x0)
*Jan 1 01:05:32.443: Mica Modem(2/5): Call Setup
*Jan 1 01:05:32.443: Enter csm_connect_pri_vdev function
*Jan 1 01:05:32.443: csm_connect_pri_vdev:tdm_allocate_bp_ts() call. BP TS allocated at bp_stream0, bp_Ch22,vdev_common 0x61593D3C
*Jan 1 01:05:32.443: ISDN Se1:15: TX -> ALERTING pd = 8 callref = 0x801B
*Jan 1 01:05:32.555: Mica Modem(2/5): State Transition to Call Setup
*Jan 1 01:05:32.555: Mica Modem(2/5): Went offhook
*Jan 1 01:05:32.555: CSM_PROC_IC2_RING: CSM_EVENT_MODEM_OFFHOOK at slot 2, port 5
*Jan 1 01:05:32.559: ISDN Se1:15: TX -> CONNECT pd = 8 callref = 0x801B
*Jan 1 01:05:32.623: ISDN Se1:15: RX <- CONNECT_ACK pd = 8 callref = 0x001B
*Jan 1 01:05:32.623: ISDN Se1:15: CALL_PROGRESS: CALL_CONNECTED call id 0xB, bchan -1, dsl 0
*Jan 1 01:05:32.623: EVENT_FROM_ISDN::dchan_idb=0x61B718D0, call_id=0xB, ces=0x0
bchan=0x1B, event=0x4, cause=0x0
*Jan 1 01:05:32.623: EVENT_FROM_ISDN:(000B): DEV_CONNECTED at slot 2 and port 5
*Jan 1 01:05:32.623: CSM_PROC_IC6_WAIT_FOR_CONNECT: CSM_EVENT_ISDN_CONNECTED at slot 2, port 5
*Jan 1 01:05:32.623: Mica Modem(2/5): Link Initiate
*Jan 1 01:05:32 UTC: %ISDN-6-CONNECT: Interface Serial1:27 is now connected to N/A N/A
*Jan 1 01:05:32.735: Mica Modem(2/5): State Transition to Connect
*Jan 1 01:05:33.911: ISDN Se1:15: RX <- ALERTING pd = 8 callref = 0x800C
*Jan 1 01:05:33.911: Progress Ind i = 0x8081 - Call not end-to-end ISDN, may have in-band info
*Jan 1 01:05:33.911: EVENT_FROM_ISDN::dchan_idb=0x61B718D0, call_id=0x800D, ces=0x1
*Jan 1 01:05:34.279: ISDN Se1:15: RX <- CONNECT pd = 8 callref = 0x800C
*Jan 1 01:05:34.283: EVENT_FROM_ISDN::dchan_idb=0x61B718D0, call_id=0x800D, ces=0x1
*Jan 1 01:05:34.283: EVENT_FROM_ISDN:(800D): DEV_CONNECTED at slot 1 and port 0
*Jan 1 01:05:34.283: CSM_PROC_OC5_WAIT_FOR_CARRIER: CSM_EVENT_ISDN_CONNECTED at slot 1, port 0
*Jan 1 01:05:34.283: Mica Modem(1/0): Link Initiate
*Jan 1 01:05:34 UTC: %ISDN-6-CONNECT: Interface Serial1:30 is now connected to XXXXXXX
*Jan 1 01:05:34.283: ISDN Se1:15: TX -> CONNECT_ACK pd = 8 callref = 0x000C
*Jan 1 01:05:34.363: Mica Modem(1/0): State Transition to Connect
*Jan 1 01:05:37.179: Mica Modem(2/5): State Transition to Link
*Jan 1 01:05:37.603: Mica Modem(1/0): State Transition to Link
*Jan 1 01:05:50.747: Mica Modem(2/5): State Transition to Trainup
*Jan 1 01:05:51.051: Mica Modem(1/0): State Transition to Trainup
*Jan 1 01:05:53.811: Mica Modem(2/5): State Transition to EC Negotiating
*Jan 1 01:05:54.055: Mica Modem(1/0): State Transition to EC Negotiating
*Jan 1 01:05:55.131: Mica Modem(2/5): State Transition to Steady State
*Jan 1 01:05:55.435: Mica Modem(1/0): State Transition to Steady State
*Jan 1 01:05:55.735: TTY66: DSR came up
*Jan 1 01:05:55.735: tty66: Modem: IDLE->(unknown)
*Jan 1 01:05:55.735: TTY66: EXEC creation
*Jan 1 01:05:55.739: TTY66: set timer type 10, 30 seconds
*Jan 1 01:06:04.579: TTY66: set timer type 10, 30 seconds
*Jan 1 01:06:07.239: TTY66: set timer type 10, 30 seconds
*Jan 1 01:06:09.723: TTY66: create timer type 1, 600 seconds
*Jan 1 01:06:11.771: TTY66: Line reset by "Exec"
*Jan 1 01:06:12.771: TTY66: Modem: (unknown)->HANGUP
*Jan 1 01:06:12.771: TTY66: destroy timer type 0
*Jan 1 01:06:12.771: TTY66: destroy timer type 1 (OK)
*Jan 1 01:06:12.771: TTY66: destroy timer type 3
*Jan 1 01:06:12.771: TTY66: destroy timer type 4
*Jan 1 01:06:12.771: TTY66: destroy timer type 2
*Jan 1 01:06:13.735: TTY66: dropping DTR, hanging up
*Jan 1 01:06:13.735: tty66: Modem: HANGUP->IDLE
*Jan 1 01:06:13.803: Mica Modem(2/5): State Transition to Terminating
*Jan 1 01:06:13.863: Mica Modem(2/5): State Transition to Idle
*Jan 1 01:06:13.863: Mica Modem(2/5): Went onhook
*Jan 1 01:06:13.863: CSM_PROC_IC7_OC6_CONNECTED: CSM_EVENT_MODEM_ONHOOK at slot 2, port 5
*Jan 1 01:06:13.863: Enter csm_enter_idle_state
*Jan 1 01:06:13.863: VDEV_DEALLOCATE: slot 2 and port 5 is deallocated
*Jan 1 01:06:13 UTC: %ISDN-6-DISCONNECT: Interface Serial1:27 disconnected from unknown , call lasted 41 seconds
*Jan 1 01:06:13.867: ISDN Se1:15: TX -> DISCONNECT pd = 8 callref = 0x801B
*Jan 1 01:06:13.867: Cause i = 0x8090 - Normal call clearing
*Jan 1 01:06:14.107: Mica Modem(1/0): State Transition to Terminating
*Jan 1 01:06:14.527: ISDN Se1:15: RX <- RELEASE pd = 8 callref = 0x001B
*Jan 1 01:06:14.527: Cause i = 0x8090 - Normal call clearing
*Jan 1 01:06:14.531: ISDN Se1:15: TX -> RELEASE_COMP pd = 8 callref = 0x801B
*Jan 1 01:06:14 UTC: %LINK-3-UPDOWN: Interface Serial1:27, changed state to down
*Jan 1 01:06:14.707: Mica Modem(1/0): State Transition to Idle
*Jan 1 01:06:14.707: Mica Modem(1/0): Went onhook
*Jan 1 01:06:14.707: CSM_PROC_IC7_OC6_CONNECTED: CSM_EVENT_MODEM_ONHOOK at slot 1, port 0
*Jan 1 01:06:14.707: Enter csm_enter_idle_state
*Jan 1 01:06:14 UTC: %ISDN-6-DISCONNECT: Interface Serial1:30 disconnected from XXXXXXX , call lasted 40 seconds
*Jan 1 01:06:14.711: ISDN Se1:15: TX -> DISCONNECT pd = 8 callref = 0x000C
*Jan 1 01:06:14.711: Cause i = 0x8090 - Normal call clearing
*Jan 1 01:06:14.907: ISDN Se1:15: RX <- RELEASE pd = 8 callref = 0x800C
*Jan 1 01:06:14.911: ISDN Se1:15: TX -> RELEASE_COMP pd = 8 callref = 0x000C
*Jan 1 01:06:14 UTC: %LINK-3-UPDOWN: Interface Serial1:30, changed state to down
*Jan 1 01:06:15.743: TTY66: restoring DTR
*Jan 1 01:06:15.743: TTY66: autoconfigure probe started
I would recommend that you involve the Telco who has provided the PRI lines, from the above debugs the variable is the PRI lines comming in from the Telco.
CSCdv02248 is specific to Xircom client modem, however that was an old issue which is not seen any more.
Thanks, Mak.
Hello Mak,
the PRI is the very same in the debugs above. The PRI is connected to our
PBX. The connection between AS5300 and PBX is the same in the three
constellations.
Can you please open a Cisco TAC case so you can have an engineer talk to you to better understand the problem & expedite resolution.
Thanks, Mak.
