Single flash for switches in stack
Is it possible to use a single flash for all the switches in stack?
In one of my locations, I found four switches in stack. When I try to check the IOS for all the switches in stack, except in master, all other are not showing any output for sh flash:
If the master switch is down, how the other switches will run!!!
Here is the output of sh ver:
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(25)SEB4, RELE
SE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 15:47 by yenanh
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(18)SE1, RELEASE SOFTWAR
(fc2)
XYZ uptime is 1 year, 13 weeks, 3 days, 19 hours, 18 minutes
System restarted at 16:38:59 CDT Sat Jul 29 2006
System image file is "flash:/c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25
SEB4.bin"
cisco WS-C3750G-16TD (PowerPC405) processor (revision G0) with 118784K/12280K b
tes of memory.
Processor board ID CAT1017N1PT
Last reset from power-on
2 Virtual Ethernet interfaces
136 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:17:E0:47:F8:00
Motherboard assembly number : 73-9143-09
Power supply part number : 341-0045-01
Motherboard serial number : CAT1016149A
Power supply serial number : LIT10070EBD
Model revision number : G0
Motherboard revision number : A0
Model number : WS-C3750G-16TD-S
System serial number : CAT1017N1PT
Top Assembly Part Number : 800-24591-04
Top Assembly Revision Number : C0
CLEI Code Number : COM1D10ARB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 17 WS-C3750G-16TD 12.2(25)SEB4 C3750-IPBASE-M
2 17 WS-C3750G-16TD 12.2(25)SEB4 C3750-IPBASE-M
3 52 WS-C3750G-48TS 12.2(25)SEB4 C3750-IPBASE-M
4 52 WS-C3750G-48TS 12.2(25)SEB4 C3750-IPBASE-M
Switch 02
Switch Uptime : 1 year, 13 weeks, 3 days, 19 hours, 5 minutes
Base ethernet MAC Address : 00:17:E0:4D:B3:00
Motherboard serial number : CAT1016149D
Power supply serial number : LIT10070ECB
System serial number : CAT1017N1S8
Top assembly part number : 800-24591-04
Top assembly revision number : C0
Switch 03
Switch Uptime : 1 year, 13 weeks, 3 days, 19 hours, 17 minute
Base ethernet MAC Address : 00:18:18:42:08:80
Motherboard assembly number : 73-9366-08
Power supply part number : 341-0107-01
Motherboard serial number : FOC10190GFQ
Power supply serial number : AZS101201Q7
Model revision number : C0
Model number : WS-C3750G-48TS-S
System serial number : FOC1019Y3Y0
SFP Module assembly part number : 73-7757-03
SFP Module revision number : A0
SFP Module serial number : CAT10160WDS
Top assembly part number : 800-25409-02
Top assembly revision number : B0
Version ID : V02
CLEI Code Number : CNMWU00ARB
Switch 04
Switch Uptime : 1 year, 13 weeks, 3 days, 19 hours, 20 minute
Base ethernet MAC Address : 00:18:18:42:00:80
Motherboard serial number : FOC10182QNZ
Power supply serial number : AZS101201Q8
System serial number : FOC1019Y3X9
SFP Module serial number : CAT10160V68
Version ID : V02
Configuration register is 0xF
Re: Single flash for switches in stack
You should be able the do a sh flash2 and see the image version
If it's not there, the switch will continue working but will not boot if reseted
You must always have a valid image on every switch in the stack
Please rate helpful post
Purple
No each switch has its own image in its own flash , to look at it do the following.
show flash1: Switch 1
show flash2: Switch 2
show flash3: Switch 3
etc , etc , etc.............
213
