10-23-2003 11:50 AM - edited 03-02-2019 11:13 AM
I have a 2600 series router with a single T-1.
My ISP had given me 32 addresses:
208.254.148.0 /27
I had assigned 208.254.149.1 as my address for my ethernet router interface.
Then, recently I started to run low on IPs and I contacted my ISP for some more addresses.
They have given me another bank of addresses but they are not contiguous to my exsiting address bank.
The new address block is:
65.137.125.0/27
How do I associate my single Ethernet interface with both sets of IP addresses?
Thanks for any advice!
Dale
Solved! Go to Solution.
10-23-2003 12:40 PM
here is an example how you do it:
Router#conf t
Router(config)#interface ethernet0
Router(config-if)#ip address 62.223.213.1 255.255.0.0 secondary
So basically you just add the keyword secondary.
Georg
10-23-2003 11:56 AM
Looks like MCI as the ISP? One way to go is that they will give you a differnet IP address to put on the routers outside interface (a WAN address) and they will handle the routing and you can just start assiging the IP addresses. I think you can also put a secondary IP address on the router for the new block IP address 65.137.125.210 255.255.255.248 secondary and that should allow you to use the new IPs as well. I am a voice and VPN guy so if this information is horribly incorrect I beg your forgivness. You get what you pay for :) I am sure you will get a pro answer shortly
10-23-2003 12:30 PM
Yes MCI is the ISP provider, my serial interface is on there network using there IP so I dont have to "route" ..still not sure how to assign the second address to the Ethernet interface..
much appreciated.
Thanks again...
10-23-2003 12:11 PM
Dale,
I agree with Travis/Dennis, I think the easiest way is to just assign a secondary IP address to your Ethernet interface.
Georg
10-23-2003 12:26 PM
Thanks! Now I have a really dumb question, how do you assign a second address to the interface?
Thanks!
10-23-2003 12:40 PM
Router#conf t
Georg
10-23-2003 12:59 PM
appreciate it...
