Webcast-Catalyst9k
SLB problem
Hi, I'm not sure does this belong here.. someone might have had same kind of problems, but any way. I need help from somewhere.
I have Catalyst 6009 switch, and I'm trying to use it with SLB to balance terminal servers load. I'm using load balancing in dispatched mode. Everything works fine with W2K servers. But when I make loopback adapter in WIN2003(as you have to in dispatched mode), and I try to delete route from WIN2003 servers routing table, it doesn't work? Is this some common problem?
1 REPLY
Anonymous
N/A
Re: SLB problem
94
