'sleep for' at level 4 ERROR
I am recieving a SYS-2-Intsched error on my 1601R router. The IOS is 12.0(9). Does anyone know what the following error means?
00:00:04: %SYS-2-INTSCHED: 'sleep for' at level 4
-Process= "Init", ipl= 4, pid= 2
-Traceback= 20EEE02 20E5B42 21F366C 20394F6 20EAE02 20EAE84 2065612 2065834
Router>ED: 'sleep for' at level 4
-Traceback= 20EEE02 20E5B42 21F366C 22EB0C0 20EAE02 20EAE84 2065612 2065834
00:00:10: %SYS-2-INTSCHED: 'sleep for' at level 4
-Traceback= 20EEE02 20E5B42 21F366C 203B67E 20EAE02 20EAE84 206561E 2065834
-Traceback= 20EEE02 20E5B42 21F366C 203EAE8 20EAE02 20EAE84 206561E 2065834
00:00:12: %QUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?
00:00:39: %IP-5-WEBINST_KILL: Terminating DNS process
00:00:39: %LINK-5-CHANGED: Interface Ethernet0, changed state to administrativel
y down
00:00:39: %LINK-5-CHANGED: Interface Serial0, changed state to administratively
down
00:00:39: %SYS-5-RESTART: System restarted --
IOS (tm) 1600 Software (C1600-Y-M), Version 12.0(9), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Tue 25-Jan-00 00:11 by bettyl
00:00:40: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed sta
te to down
00:00:40: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state
to down
Re: 'sleep for' at level 4 ERROR
This looks like an IOS bug to me. Have seen similar error messages, happening in diff router models. I am not sure about a workaround for this, but if you keep getting this message continously every second, you should consider opening a case with Cisco TAC. One such similar bug is with ID, (with "sleep for at level 3") is CSCdw20801. This neednt be the reason in your case, though.
Did the router crash by anychance (get reloaded due to software crash). Please provide outputs of "show stack", "show version" for further troubleshooting, if the router did crash.
Thanks for your reply. This error only occurs during booting. It does not occur continuously. I have 2 other 1601R's, so I have been able to try other IOS's. I still get the same errors on the bad 1601R. The other 1601's work fine with the IOS from the BAD 1601R. The bad 1601R did not crash. I would think this would indicate a hardware problem, but I can't find any info about these errors. Maybe it is a ROM problem. Thanks for your help.
When a 1600 doesn't have any start-up config and it is booted, sometimes it freaks for a moment and gives traceback messages. If there is anything 'saved' in the startup config, you don't see any of that.
860
