09-28-2003 09:22 PM - edited 03-02-2019 10:38 AM
I'm using SLM 2.0 to do a roundtrip icmpecho on some of my routers. (router ios is 12.1E)
However, after enabling the SLC, i realise that my router does not show the correct target IP address.
My IP is 10.152.30.33, instead i get 10.63.30.33
I get the below from my router when i do a " sh rtr configuration ".
Entry Number: 3
Owner: 5:slmuser:IcmpEcho@@116@@nwhq01@@1064803881991:10.152.30.33
Tag: 3
Type of Operation to Perform: echo
Reaction and History Threshold (milliseconds): 200
Operation Frequency (seconds): 300
Operation Timeout (milliseconds): 5000
Verify Data: FALSE
Status of Entry (SNMP RowStatus): active
Protocol Type: ipIcmpEcho
Target Address: 10.63.30.33
Source Address: 0.0.0.0
Target Port: 0
Source Port: 0
Doing a sh rtr collection -statistics give me a time-out as below:
Entry Number: 3
Modification Time: 12:46:30.000 CCT Mon Sep 29 2003
Diagnostics Text:
Last Time this Entry was Reset: Never
Number of Octets in use by this Entry: 2802
Connection Loss Occurred: FALSE
Timeout Occurred: TRUE
Over Thresholds Occurred: FALSE
Number of Operations Attempted: 2
Current Seconds Left in Life: 2147483647
Operational State of Entry: active
Latest Completion Time (milliseconds): 0
Latest Operation Start Time: 12:51:30.000 CCT Mon Sep 29 2003
Latest Operation Return Code: timeout
Latest 10.63.30.33
Any advice appreciated.
Thanks.
Solved! Go to Solution.
10-06-2003 07:19 AM
Seems like its hitting the bug CSCdv43095. The workaround given in the bug should fix the issue.
10-06-2003 07:19 AM
