Slow 3620 RAS connection
Have a 3620 RAS router w/ PRI/digital modems connected to T1 that I can't seem to connect to any faster then 24k bps it also has a problem dropping connections.
Any input is greatly appreciated
Here's a look at the running config.
ras_3620#show config
Using 1819 out of 30712 bytes
! Last configuration change at 10:50:37 UTC Fri Mar 22 2002
! NVRAM config last updated at 10:51:27 UTC Fri Mar 22 2002
version 11.3
hostname ras_3620
aaa new-model
aaa authentication login default enable
aaa authentication ppp default radius local
aaa accounting exec default start-stop radius
aaa accounting network default start-stop radius
enable secret 5 $1$rE0f$SGo2HrotsKP0UVWHLfa.x0
enable password cisco
username biff password 0 asdf
ip subnet-zero
no ip domain-lookup
async-bootp nbns-server 10.0.0.23 10.0.0.24
isdn switch-type primary-5ess
controller T1 0/0
framing esf
linecode b8zs
pri-group timeslots 1-24
description PRI for dial-in tel:7088162031 mci circuit-id:HCGS792366
controller T1 0/1
shutdown
process-max-time 200
interface FastEthernet0/0
ip address 10.0.0.15 255.255.0.0
interface Serial0/0:23
no ip address
encapsulation ppp
isdn incoming-voice modem
ppp authentication pap
interface Group-Async1
ip unnumbered FastEthernet0/0
encapsulation ppp
dialer in-band
dialer idle-timeout 3600
dialer-group 1
async mode interactive
peer default ip address pool dialin
group-range 33 56
ip local pool dialin 10.0.6.1 10.0.6.23
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.1
no logging console
dialer-list 1 protocol ip permit
snmp-server community public RO
radius-server host 10.0.0.23 auth-port 1812 acct-port 1813
radius-server host 10.0.0.24 auth-port 1812 acct-port 1813
radius-server key broadway
line con 0
exec-timeout 0 0
line 33 56
password cisco
autoselect ppp
modem InOut
transport input all
line aux 0
line vty 0 4
Bronze
Re: Slow 3620 RAS connection
It wont take much to bring the modems (I am assuming they are MICA) to good looking connect speeds.
Since you are running some flavour of IOS rel 11.3 which is pretty old so I am assuming your modem code is not uptodate either. Therefore, please upgrade your MICAs to portware 2.7.3.0 as well as IOS to some latest 12.1 or 12.2 and see the difference.
~Zulfi
What Zulfi said, and review this doc:
Overview of General Modem and NAS Line Quality
http://www.cisco.com/warp/public/76/modem-macro.html
Josh
118
