Slow Download speed with 3640 MICA 6DM and CT1
I'm getting really slow download(1.2 Kbps) speeds, but high connection speeds(44.6kbps) with a 3640 with a MICA 6dm with 24 lines and a CT1.
The router is running a really old OS 11.29(17)which I will upgrade tomorrow. Modem firmware 2620 Any Ideas?
Thanks!
1 REPLY
Re: Slow Download speed with 3640 MICA 6DM and CT1
Upgrading IOS and Modem Firmware is a good idea but not likely the problem. Check for other unused protocols on the remote PC like NetBui or IPX/SPX. So I assume the server your dial users are connecting to is hanging off the same LAN as the 3640? Is it gateway’d at the 3640 or through another router. You might need to troubleshoot this a bit with a Cisco tech.
124
