12-14-2001 06:59 AM - edited 03-01-2019 07:45 PM
What is it that i am looking at when i log into a cisco 1700 router encapsulated for frame relay. I see lots of errors that i am not understanding. Such as out put errors, Frame and other such things that appear when i do a Sh int s0 i dont know what it is that these are each explaining. If some one is able to help me i would greatly appreciate it and i will be more then helpfull to better explain if needed. Im sorry but im working my way to become CCNA. thanks
12-17-2001 07:18 PM
I very much doubt this is the forum to answer your question, as it is rather vague and lacks any form of detail.
I would humbly suggest that you do a course on Frame Relay, or buy some technical books on Frame Relay... or make the Cisco Documentation CD your bed-time reading activity.
01-02-2002 05:18 PM
I must agree with my curt and unhelpful colleague about needing background knowledge on FR. However until you get it this problem isn't going to magically go away soooo:
Check the encapsulation
check the LMI type (should match upstream provider)
make sure the interface isn't looped (sounds like it's passing *some* traffic so it shouldn't be)
make sure the interface sends keepalives
if you're using Frame relay inverse-arp maybe configure map statements
check dlci number if you use subinterfaces
Hope that helps
01-03-2002 08:17 AM
Jason,
This link is for troubleshooting serial problems in general, not necessarily Frame Relay. It should help you to decipher some of the different error types.
http://www.cisco.com/warp/public/112/chapter15.htm
Here is a linke that has more info on Frame Relay than you ever wanted:
http://www.cisco.com/cgi-bin/Support/PSP/psp_view.pl?p=Internetworking:Frame_Relay
Scott
