Community Member
Slow V90 connect and fast V90, on simple network scheme.
Please help with this problem. I have network scheme:
Cisco 3620(30 Mica modem) <-ISDN EuroISDN-> Passport 6440 (Voice Network) <- EuroISDN-> Meridian M01 <-> Courier V90 modem.
Debug for this connect from Cisco:
dialup>sh mod op 0/11
Modem (0/11) Operational Status:
Parameter #0 Disconnect Reason Info: (0x0)
Type (=0 ): <unknown>
Class (=0 ): Other
Reason (=0 ): no disconnect has yet occurred
Parameter #1 Connect Protocol: LAP-M
Parameter #2 Compression: V.42bis both
Parameter #3 EC Retransmission Count: 2
Parameter #4 Self Test Error Count: 0
Parameter #5 Call Timer: 64 secs
Parameter #6 Total Retrains: 1
Parameter #7 Sq Value: 3
Parameter #8 Connected Standard: V.90
Parameter #9 TX,RX Bit Rate: 28000, 24000
Parameter #11 TX,RX Symbol Rate: 8000, 3200
Parameter #13 TX,RX Carrier Frequency: 0, 1829
Parameter #15 TX,RX Trellis Coding: 0, 16
Parameter #16 TX,RX Preemphasis Index: 22, 0
Parameter #17 TX,RX Constellation Shaping: Off, Off
Parameter #18 TX,RX Nonlinear Encoding: Off, Off
Parameter #19 TX,RX Precoding: Off, Off
Parameter #20 TX,RX Xmit Level Reduction: 0, 0 dBm
Parameter #21 Signal Noise Ratio: 34 dB
Parameter #22 Receive Level: -20 dBm
Parameter #23 Frequency Offset: 0 Hz
Parameter #24 Phase Jitter Frequency: 0 Hz
Parameter #25 Phase Jitter Level: 0 degrees
Parameter #26 Far End Echo Level: -28 dBm
Parameter #27 Phase Roll: 0 degrees
Parameter #28 Round Trip Delay: 50 msecs
Parameter #30 Characters transmitted, received: 3993, 47
Parameter #32 General Portware Information: 22
Parameter #33 PPP/SLIP packets transmitted, received: 0, 0
Parameter #35 PPP/SLIP packets received (BAD/ABORTED): 0
Parameter #36 EC packets transmitted, received OK: 63, 45
Parameter #38 Moving Average of EC packets (Received BAD/ABORTED): 291
Parameter #39 Robbed Bit Signalling (RBS) pattern: 0
Parameter #40 Digital Pad: 7.125 dB, Digital Pad Compensation: None
Parameter #41 V110 frames received bad: 0
Parameter #42 V110 frames received good: 0
Parameter #43 V110 frames transmitted: 0
Parameter #44 V110 sync lost: 0
Line Shape:
Diagnostic data from modem after connect:
ati11
Extended Link Diagnostics...
Modulation Protocol V.90/V.34+
Speed 28000/24000
Carrier Freq ( Hz ) NONE/1829
Symbol Rate 8000/3200
Trellis Code NONE/16S-4D
Nonlinear Encoding NONE/OFF
Precoding NONE/OFF
Shaping ON/OFF
Preemphasis Index NONE/0
Recv/Xmit Level (-dBm) 30.7/18.3
SNR ( dB ) 31.0
Near Echo Loss ( dB ) 18.9
Far Echo Loss ( dB )
Roundtrip Delay (msec) 48
Timing Offset ( ppm) -1530
Carrier Offset ( ppm) 17
Speedshifts 1 requested(0 up, 1 down)/2 granted
V.90 Status Au,5,12Y,19.8,-18,0N,0,39.0,37.7
ati16
Advanced Voice Courier External Channel Probe...
-16 . . x x x x X x x x x x x x x x x x . . . . . . . 1
-18 . X X X X X X X X X X X X X X X X X X X X X x . . 3
-20 . X X X X X X X X X X X X X X X X X X X X X X . . 5
-22 X X X X X X X X X X X X X X X X X X X X X X X X . 7
-24 X X X X X X X X X X X X X X X X X X X X X X X X . 9
-26 X X X X X X X X X X X X X X X X X X X X X X X X . 11
-28 X X X X X X X X X X X X X X X X X X X X X X X X X 13
Level --------------------Frequency-------------------- Attn
0 0 0 0 0 0 1 1 1 1 1 1 1 2 2 2 2 2 2 3 3 3 3 3 3
1 3 4 6 7 9 0 2 3 5 6 8 9 1 2 4 5 7 8 0 1 3 4 6 7
5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5 0 5
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
This connect have slow connect speed, why?
For testing purposes i organize connect to other Cisco 5300, scheme connect:
Cisco 5300 <-> Long Distance Network!! <-> R2 <-> Meridian M01 <-> EuroISDN <-> Passport 6400 (Voice Network) <-> Meridian M01 <-> Courier V90 modem.
I no have info for this connect from Cisco 5300 (is not my Equipment).
I have diag info from modem:
ati11
Speed 37333/21600
Precoding NONE/OFF
Shaping ON/OFF
Preemphasis Index NONE/6
Recv/Xmit Level (-dBm) 24.2/18.2
SNR ( dB ) 36.2
Near Echo Loss ( dB ) 18.6
Roundtrip Delay (msec) 9
Timing Offset ( ppm) -1473
Carrier Offset ( ppm) 142
Speedshifts 1 requested(0 up, 1 down)/1 granted
V.90 Status Au,5,11N,11.3,-14,0N,0,47.6,33.5
ati16
-20 . . . . . . x . . . . . . . . . . . . . . . . . . 0
-22 x X X X X X X X X X X X X X X X X X x x x x . . . 2
-24 X X X X X X X X X X X X X X X X X X X X X X X . . 4
-26 X X X X X X X X X X X X X X X X X X X X X X X x . 6
-28 X X X X X X X X X X X X X X X X X X X X X X X X . 8
-30 X X X X X X X X X X X X X X X X X X X X X X X X . 10
-32 X X X X X X X X X X X X X X X X X X X X X X X X x 12
And two connect:
ati11
Speed 40000/21600
Precoding NONE/OFF
Shaping ON/OFF
Recv/Xmit Level (-dBm) 29.5/18.3
SNR ( dB ) 40.5
Timing Offset ( ppm) -1500
Carrier Offset ( ppm) 64
V.90 Status AA,5,11N,11.1,0,0N,0,42.0,35.9
ati16
-20 . . . . . x x . . . . . . . . . . . . . . . . . . 0
This connect over identical network have some differences? Why?
May be change config in Cisco 3620?
IOS on 3620 12.5-10, Portware 2.7.3
Config from Cisco 3620:
Current configuration : 3019 bytes
version 12.1
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname dialup
aaa new-model
aaa authentication login default local
aaa authentication ppp default group radius local
aaa authorization network default group radius local
aaa accounting network default wait-start group radius
enable secret 5 xxxxxxxxxx
enable password 7 xxxxxxxxx
username xxxxxxxxx
modem call-record terse
no ip subnet-zero
ip name-server XXXXXXXXXXX
isdn switch-type primary-net5
modemcap entry mica-v90v2:MSC=&F&D2S10=100S32=3S39=10S40=0S52=0
modemcap entry mica-NO56FLEX:MSC=&F&D2S0=2S10=50S39=7S52=0
modemcap entry mica-V34:MSC=&F&D2S0=3S10=50S25=2S29=1S39=6S40=6
controller E1 1/0
pri-group timeslots 1-31
controller E1 1/1
interface FastEthernet1/0
ip address 212.57.160.62 255.255.255.252
no ip mroute-cache
speed auto
half-duplex
no cdp enable
interface Serial1/0:15
no ip address
isdn incoming-voice modem
no cdp enable
interface Serial1/1:15
no ip address
no cdp enable
interface Group-Async0
ip unnumbered FastEthernet1/0
ip access-group 101 in
encapsulation ppp
no ip mroute-cache
autodetect encapsulation ppp
async dynamic address
async mode interactive
peer default ip address pool dial test
no fair-queue
no cdp enable
ppp authentication pap
group-range 1 30
ip local pool test XXXXXXXXXX XXXXXXXXX
ip local pool dial XXXXXXXXXX XXXXXXXXX
ip classless
ip route 0.0.0.0 0.0.0.0 XXXXXXXXX
no ip http server
logging source-interface FastEthernet1/0
logging XXXXXXXXXXXX
access-list (Skip)
dialer-list 1 protocol ip permit
no cdp run
radius-server host xxxxxxxxxxx auth-port 1812 acct-port 1813
radius-server retransmit 3
radius-server key xxxxxxxxxx
line con 0
exec-timeout 0 0
line 1 30
exec-timeout 300 0
no flush-at-activation
modem InOut
modem autoconfigure type mica-V90v2
transport preferred none
transport input all
escape-character NONE
autoselect during-login
autoselect ppp
line aux 0
line vty 0 4
access-class 10 in
exec-timeout 0 0
terminal-type AT386
escape-character BREAK
telnet transparent
ntp clock-period 17180102
ntp server xxxxxxxxx
end
1 REPLY
Re: Slow V90 connect and fast V90, on simple network scheme.
Config on 3600 is fine along with the modem firmware 2.7.3.0..Now test the local loop first.
Try to make the loopback call from 3600..Means reverse telnet to one of the modem and call your own number..So the call will hit the switch one one ds0 and comback on other ds0..
Once the call connect, issue "sh mo op x/y" on those modems and you should be getting
Parameter #8 Connected Standard: V.34+
Parameter #9 TX,RX Bit Rate: 33600, 33600
You will find a good "modem troubleshooting guide" at
http://www.cisco.com/warp/public/471/index_14280.html
Also try to use the modemcap for 2.7.3.0 which is located at
http://www.cisco.com/warp/public/471/recc_modemcaps.html#16
126
