small problem in NAT
My network is as follows.
R1 via s0 is connected to R3 s1
R2 via s0 is connected to R3 s2
R3 is the NAT border router. R1 is inside with private IPs and R2 is an outside router on the Internet with public IPs
in R1
interface serial 0
ip address 10.10.10.1 255.255.255.0
bandwidth 64
in R3
interface serial 1
ip address 10.10.10.2 255.255.255.0
clock rate 64000
ip nat inside
interface serial 2
ip address 20.20.20.2 255.255.255.0
clock rate 64000
ip nat outside
ip nat inside source static 10.10.10.1 20.20.20.2
in R2
inteface serial 0
ip address 20.20.20.1 255.255.255.0
bandwidth 64
The problem that I have is when I give the command in interce serial 2 in R3 ip nat outside I cannot ping from R2 to R3. But if I remove the command ip nat outside from interface serial 2 in R3, then I can ping from R2 to R3.
Can someone please tell me where have I gone wrong?
Thank you very much!
Omal.
VIP Purple
Re: small problem in NAT
Hello Omal,
as far as I can see, the statement:
could be the culprit. In the NAT table of R3, the IP address of your serial 2 interface on R3 is translated to 10.10.10.1, hence when you ping ping 20.20.20.2, your R2 is actually pinging 10.10.10.1.
I would suggest to change the static NAT translation to another IP address from the R1 range, e.g.:
ip nat inside source static 10.10.10.3 20.20.20.2
Don´t forget to clear the NAT translation after that:
clear ip nat translation *
HTH,
Georg
Hi Georg
What do you think is the difference between
AND
10.10.10.1 is the local IP address and that has to be translated to 20.20.20.2 when it goes out to the Internet as 10.10.10.1 is not routable. Therefore what ever the packet going out of Serial 2 interface of R3 will have the new source address as 20.20.20.2
However the moment I remove the command 'ip nat outside' from Serial 2 interface in R3, I can ping to 20.20.20.2 from R2.
I'll try what you say but I don't know whether or not will it work. Besides it's no the command 'ip nat inside source static NAT' but the moment you remove 'ip nat outside' from Serial 2 in R3, I can ping from R2 to R3's Serial 2.
Anyway thank you very much for taking time to give me an answer.
Omal
VIP Purple
Hello Omal,
enable ip nat debugging on router R3:
debug ip nat
term mon
When you ping 20.20.20.2 from R2´s IP address 20.20.20.1, you will see the following:
R3#
00:08:32: NAT*: s=20.20.20.1, d=20.20.20.2->10.10.10.1 [10]
00:08:34: NAT*: s=20.20.20.1, d=20.20.20.2->10.10.10.1 [11]
00:08:36: NAT*: s=20.20.20.1, d=20.20.20.2->10.10.10.1 [12]
00:08:38: NAT*: s=20.20.20.1, d=20.20.20.2->10.10.10.1 [13]
00:08:40: NAT*: s=20.20.20.1, d=20.20.20.2->10.10.10.1 [14]
The destination 20.20.20.2 gets translated to 10.10.10.1 because of the ip nat outside command on R3´s serial 2 interface.
HTH,
Georg
Hi Georg
Thank you so much for taking such an effort to give me an answer, I really appreciate it.
Hmmmm, this teaches me something new in NAT. I never thought about this. But Georg do you think me changing the command into
ip nat inside source static 10.10.10.3 20.20.20.2 will work? However I'll try it out when I go to work tomorrow. Then is that the solution for this problem?
by the way what do you mean by HTH? -:)
I have aonther problem, wish you know the answer for that as well. None of these debug command work in my routers. Do you think it is the IOS?
Thank you so much!!!
Omal
VIP Purple
Hello Omal,
the debug commands are supported starting in IOS version 11.2, remember that the debug commands are issued from the privileged exec command line:
R3#debug ip nat
R3#term mon
HTH - that is short for Hope This Helps, I guess it is used frequently amongst Internet users...another one that you might come across often is AFAIK (as far as I know)...:)
Georg
Hi Georg
Many thanks for your quick reply.
My IOS is 12.x I can't remember the exact version, but one thing that I know is, it doesn't have IGRP. I asked that in this forum then someone said from a new IOS it has been removed or something. I don't know whether Cisco has removed debug also.
I will try what you have said tomorrow when I go to work.
Thank you very much for your kind advices especially about those Internet short codes -:)
Would you also mind telling me, what is this command:
R3#term mon
Talking about debug, none of the debugging is working in my routers, I am not sure as to why.
Best regards,
Omal
VIP Purple
Hello Omal,
strange that the debug commands are not working. can you post the output of the command:
show version
? The command term mon is short for terminal monitor, it allows you to view the debug output on your terminal. To disable it after you are finished type:
term no mon
Georg
Hi Georg
Thank you so much for solving something that I couldn't solve for quite sometime.
It was not actually debug command wasn't working, it was actually I did not know term mon command. I didn't know that I had to give that command after debug command. I just tried that and it worked. Thank you so much Georg.
But I don't have IGRP and that's for sure. Let me post the show version.
Best regards,
Omal
R1#show version
IOS (tm) 2500 Software (C2500-IS-L), Version 12.2(15)T8, RELEASE SOFTWARE (fc2)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 09-Sep-03 23:12 by pwade
Image text-base: 0x0307FFEC, data-base: 0x00001000
ROM: System Bootstrap, Version 5.2(8a), RELEASE SOFTWARE
BOOTLDR: 3000 Bootstrap Software (IGS-RXBOOT), Version 10.2(8a), RELEASE SOFTWAR
E (fc1)
R1 uptime is 53 minutes
System image file is "flash:/c2500-is-l.122-15.T8.bin"
cisco 2500 (68030) processor (revision D) with 16384K/2048K bytes of memory.
Processor board ID 02368247, with hardware revision 00000000
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
VIP Purple
Hello Omal,
possibly your IP Plus does not support IGRP. According to the software advisor, any of the IOS releases below support it (not sure if you can load those onto your 2503):
12.2(11)T10
c2500-is-l.12.2-11.T10
12.2(21a)
c2500-is-l.12.2-21a
12.1(5)T17
c2500-is-l.12.1-5.T17
Georg
Hi Georg
Thank you so much for taking time to answer my questions. I really appreciate it.
When it comes to NAT, I don't understand as to why do you always config int e 0 as ip nat inside and int s 0 as ip nat outside
Can't it be the other wat round, i.e. int e 0 as ip nat outside and int s 0 as ip nat inside
I also don't understand what exactly the meaning of ip nat inside source static command.
what if we do it as follows:
interface ethernet 0
ip nat outside
interface serial 0
ip address 203.115.19.225
ip nat inside
***in this case I have changed ip nat inside & outside interfaces from the normal one that we use****
ip nat outside source static 10.10.10.x 203.115.19.225
what can't we do it like this.
Please be kind enough to let me know if possible.
Best regards,
Omal.
Hello Georg and Omal,
It looks like the router R1 does not have a route to answer the ping which is translated correctly. If R1 does not have a route for 20.20.20.0/24, it cannot respond to a ping.
Nadine.
Hi Nadine
Yes, I guess you have a point there. Because (I can't remember it now, I'll update it on Monday) if I give a default route in R1, it works I guess. But as I said I can't remember 100% about it, but let me try that out and update you on Monday.
But then there will be another problem. Then how can we check if S2 in R3 is up or not, if we can't ping to that interface's IP address. When we ping, if we don't get a reply, the problem could be somewhere else even. This reminds me of the command 'ip unnumbered'
You can't ping and see if that interface is up or not.
Thanks a lot!
Omal.
124
