sna connection over a cip-router
hi,
my question:
i have a cisco7513 router which is connected to an ibm host over a cip-card.
there is the following configuration on the card:
lan TokenRing 7
source-bridge 1127 1 1120
adapter 15 4000.1090.0002
name Geos_Tir
and so on.
there is a sna-server which has a connection to the host over this adapter - everything is fine.
now they want to install a new sna-session (lu6.2) from that server to the same adapter.
but it is not possible to configure the new session on the server with the same sap-value (04) as the first session has.
so we tried with a sap of 08 but it does not work - i think my cip-router only "hears" to sap 04.
is there a possibility to configure a second sap value ?
must this new sap-value also match with the config on the ibm-host ??
any idea ???
thanks a lot !
  • Other Network Infrastructure Subjects
1 REPLY
Bronze
Re: sna connection over a cip-router
As I said previously, there is no SAP value coded on the router. It is specified on the XCA major node only so you need to set up a second XCA major node with the new SAP value.
85
