SNA over Frame
I have just fired up a new Frame circuit with AT&T (256k) between two offices on opposite sides of the country to run traffic (IP and SNA (for printing)). This is to replace a current circuit with another provider. We brought the circuit up to test it and the IP traffic was flowing nicely. The SNA traffic (for printing) would not respond however. We are using two 2501's to connect the two sites, with Paradyne CSU/DSU's. Is there anything in the config below that you can think would need tweaking? I just basically copied the config from serial 0 where the old line was to s1...so it should be the same and s0 with the old ISP was working great, even at a lower (128k) rate. Something about the SNA traffic, even though I know it's just encapsulated IP.
interface Serial1
ip address 32.100.100.1 255.255.255.128
encapsulation frame-relay
no ip route-cache
no ip mroute-cache
bandwidth 256
frame-relay interface-dlci 100
frame-relay lmi-type cisco
bridge-group 1
That's the config...it's the same on both sides of the wan...thanks for any thoughts!
Re: SNA over Frame
Greetings:
Use sub-interfaces and you should be fine. Bridge maps do not build dynamically as IP ones do. A "show frame map" will confirm if the bridge map is there.
Thanks...Steve
Re: SNA over Frame
Thanks Steve! A quick "rookie" question for you...can you briefly explain the purpose of a sub-interface?
Re: SNA over Frame
Never mind...I read enough on them now to know what they are and why they are used.
Re: SNA over Frame
One other thing Steve - do I need subinterfaces on both sides?
Re: SNA over Frame
Why are you bridging across the WAN, why no use DLSw? Then it is all IP, you don't have to worry about spanning-tree or any bridged traffic.
Just a thought
119
