SNMP problem
SNMP works on port UPD 161, right?
i am trying to filter incoming SNMP packets by applying access-list on my incoming interface, its not working.
Any idea what can be the problem, are there multiple ports involve..just like FTP, for instance
Silver
Re: SNMP problem
SNMP Traps use 162. May be thats what you are getting.
Thanks.
Bronze
Re: SNMP problem
whats you access-list look like. Are you checking for 161 in the destination port?
Bronze
Re: SNMP problem
Are you trying to filter SNMP packets destined to the router itself? Typically the way this is done is by giving an access-list number in the snmp community statement:
snmp-server community public view myview RO 11
Then you create access-list 11 to restrict source hosts as appropriate, and it determines which hosts can and cannot send SNMP queries to your router.
Given the above, I suppose it's conceivable that normal access lists applied to an interface don't block SNMP traffic to the router itself. But I've never tried doing it this way, so I can only speculate.
105
