snmp trap for dialer interface
hi,
i have a core 7206 router with e1 cards.
some access-router dial in this e1 card for fr-backup.
i have configured one diale-interface per access-router for backup.
now i want that i receive a snmp-trap if one of these dialer interface went from down to up because this means that a backup-connection is active .
how can i achive this - any idea ?
no i have the following config:
controller E1 2/0
pri-group timeslots 1-31
interface Serial2/0:15
description MPLSRBGOPE02: PrimaryInterface Se2/0:15
no ip address
encapsulation ppp
timeout absolute 600 0
dialer pool-member 1
dialer pool-member 2
snmp trap isdn-calls
isdn switch-type primary-net5
isdn caller 123
no cdp enable
ppp authentication chap callin
ppp multilink
interface Dialer2
description MPLSRBGOPE02: Dialer to ss(Di2)
bandwidth 128
ip address 172.16.27.1 255.255.255.252
max-reserved-bandwidth 95
service-policy output backup_qos
encapsulation ppp
load-interval 30
dialer pool 2
dialer remote-name ss
dialer max-call 2
dialer-group 1
no cdp enable
ppp chap hostname aa
ppp chap password 123
ppp multilink
ppp multilink fragment delay 20
ppp multilink load-threshold 1 either
ppp multilink interleave
snmp-server community aa RW aa
snmp-server ifindex persist
snmp-server location aa
snmp-server system-shutdown
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps xgcp
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps channel
snmp-server enable traps hsrp
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps envmon fan shutdown supply temperature
snmp-server enable traps aaa_server
snmp-server enable traps bgp
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps ipmulticast
snmp-server enable traps msdp
snmp-server enable traps rsvp
snmp-server enable traps frame-relay
snmp-server enable traps frame-relay subif
snmp-server enable traps rtr
snmp-server enable traps dial
snmp-server enable traps dsp card-status
snmp-server enable traps voice poor-qov
snmp-server host 10.1.1.1 public
Anonymous
N/A
Re: snmp trap for dialer interface
I think if you have the relevant MIBs, for eg. the CISCO-ISDN-MIB, you should be able to generate traps.
Silver
modify this line
to
snmp-server host 10.1.1.1 public snmp
669
