snmpwalk on CAT2950-24 ver c2950-i6q4l2-mz.121-9.EA1.bin not working
Customer has 2950-24 running above IOS the snmpwalk does not work
whereas the same machine running c2950-c3h2s-mz.120-5.3.WC.1.bin is ok
Is this to do with the 2950-24 being standard image in the 12.1 code and was enterprise in the 12.0 code?
  • Other Network Infrastructure Subjects
Silver
Re: snmpwalk on CAT2950-24 ver c2950-i6q4l2-mz.121-9.EA1.bin not
What MIB are you trying to access with your SNMPWalk? Possibly something that was either changed/depreciated/or taken out. Without knowing what specific MIB/OID your customer is looking for it's hard to say for what the issue is.
Don
bew
I am having a similar problem. What I see is that dot1dBaseNumPorts, dot1dBasePortTable, dot1dFDBPortTable only report on active ports in 12.1(9). In 12.0(5) all ports are retrieved. We are using the Cisco 2950 going from 12.0(5) to 12.1(9). Any ideas?
124
