SNMS 1.5 Problems with Essentials ManagedDeviceMap
I have installed SNMS by a Customer. Reason was, that he had
performance problems with SNMS Version 1.5. So i have deinstalled all
components (Cisco SNMS and WhatsUp) and I also deleted the Program
File Folder. Than I installed SNMS Version 1.5 new with IDU 5.0,
Update 1 and than IDU 7.0.
Afterwards I have backuped the map files for whatsup. Than I imported
the devices from the maps to Essentials. Now my problem starts, when
I click on Cisco Works WhatsUp Page it starts to generate the
Essentials ManagedDeviceMap. In WhatsUp Gold it creates only empty
map pages for each device. It seems, that Cisco Works has problems to
export the information from the inventory to WhatsUp. And always when
I log on to Cisco Works it starts to export the Essentials
ManagedDeviceMap. Does anybody have an idea what I could do? Is there
a possibility to stop the creation of this map?
Thanks for any help.
Erich Schommarz
Re: SNMS 1.5 Problems with Essentials ManagedDeviceMap
Can you let me know the following ?
1. Is the Map getting created in the customer's file
system? Please do a search on the file system with
the name of the map. There is a possibility that the
directories which the maps are supposed to be stored
does not have proper permissions.
Directory information on where the map should be
stored is available under Configure->Web Server-
>General->Map Directory.
2. Get me the stdout.log from
Directory>/MDC/tomcat
directory which might give us a clue on the problem.
-Ganesh
Hello Ganesh
Thanks for your answer. Unfortunately the customer has installed the whole server new and we will install SNMS new. If we will have again problems i will check your points.
Erich
105
