Solution Advise
Experiencing some problems in the below said scenerio.I had two links for load balancing and also for redundant purpose.
link 1 : Frame-relay link , end-to-end tunnel , RIPv1 routing protocol, bandwidth 64k
link 2: 64 k LL link , end-to-end tunnel . RIPv1 routing protocol,bandwidth 64k
physical topo:
link 1 : end - to-end serial interface connectivity , but using tunnel
link 2: In one end serial and the other end ethernet , but using tunnel
experiencing problem on the second link , enormous error in the NMS and interface, I am suspecting about teh diff. encap on the second link might cause problems , could anybody can advise what could be the reason...
1 REPLY
Re: Solution Advise
Here is a link with some frame-relay troubleshooting tips:
http://www.cisco.com/warp/public/125/12.html
78
