Webcast-Catalyst9k
solution to routing between LANs
Hello, there is one request from shopfloor to enable the routing between several LANs, no WAN access is needed, is there any simple cost-effective router available for it? Thanks!
Re: solution to routing between LANs
What kind of lans / ethernet, tokenring ?
are the lans on switches or hubs ?
only ethernet 10/100M, both switches and hubs exist.
Thanks!
You can go for Cisco Catalyst 2948G-L3.
http://www.cisco.com/univercd/cc/td/doc/pcat/c2948gl3.htm#CFHBDEBA
or Cisco 1600 Modular Desktop Access Router.
http://www.cisco.com/univercd/cc/td/doc/pcat/1600.htm#CIHHAHBE
122
