01-21-2002 05:06 AM - edited 03-01-2019 08:08 PM
We have 2 sites each site has a 2600 router with 1 10/100 interface, a Serial WAN and ISDN interface card installed that will be used as a backup.
The sites are connected via a BT Meagstream (2mb) connection between Megastream and Router is x.21.
Each site is on a Private Class C range.
Network 1 is on 192.168.168.0 255.255.255.0
Network 2 is on 192.168.169.0 255.255.255.0
All we wish to do is communicate between the sites, what configuration steps do we need to make in order to achieve this?
A How-to or a few pages to read through would be most appreciated.
01-21-2002 05:40 AM
router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
router(config)#int ethernet 0/0
router(config-if)#ip address 192.168.168.1 255.255.255.0
router(config-if)#no shut
do this to apply an IP address to the ethernet interface, and then this to allow the serial to take the IP addss of the ethernet interface.
router(config-if)#int s0/0
router(config-if)#ip unnumbered e0/0
...and then this to apply EIGRP as your routing protocol
router(config)#router eigrp 100
router(config-router)#network 192.168.168.0
do exactly the same on the other router but use the other network range for your routing protocol and interfaces.
This is all assuming you know the basic commands.
HTH... Karl
01-23-2002 02:59 AM
