Webcast-Catalyst9k
Source Base Routing in PIX and 2500
Hi All Pro.
I need your advice on how to route traffic based on Source Network IP on PIX515 and C2500.
I am not sure that which technology will be needed. Please help me on it.
Thank you in advance.
Amnuay
Bronze
Re: Source Base Routing in PIX and 2500
Policy Routing does it on Cisco routers. Don't know if PIX's have such functionality.
Thanks to tbaranski for your reply. However am I need to implement the other technology such as BGP? or only route policy?
can I also use route policy for default route? eg. Network A go default routed using router A and Network B go default routed using Router B on the same LAN.
Many Thanks.
Bronze
You don't need to implement BGP for source-based routing, and you can do the type of default routing you asked about. See http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800c75d2.html for some configuration instructions.
To my knowledge, there is no source-based routing on the PIX firewall.
96
