source routing in switches
hi everybody
I know that source routing is implemented in routers by Policy route-map . But I want to have this feature on switch.could you pls help me that how can I set source routing on switches .
thanks
Re: source routing in switches
Policy based routing can be implemented in Layer 3 switch in the same way as you do it on the router.
The only difference is, it will be applied on the SVI (interface vlan) instead of ports (ethernet/aerial) on the router.
Here is a sample
route-map test permit 1
match ip address 1
set ip next-hop 172.20.76.166
access-list 1 permit 172.16.100.0 0.0.0.255
interface VLAN 1
ip address 172.16.100.1 255.255.255.0
ip policy route-map test
Narayan
thanks for your attention. I config 3750 just like this:
no aaa new-model
switch 1 provision ws-c3750-24ts
vtp domain vtp-a
vtp mode transparent
ip subnet-zero
ip routing
ip dhcp pool vlan1
network 192.168.0.0 255.255.255.0
default-router 192.168.0.244
--More-- ip dhcp pool vlan2
network 20.20.20.0 255.255.255.0
default-router 20.20.20.1
ip dhcp pool vlan3
network 172.31.131.0 255.255.255.240
default-router 172.31.131.1
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 2
name test
vlan 3
name Arian
--More-- !
interface FastEthernet1/0/1
switchport mode access
spanning-tree portfast
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
--More-- !
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
switchport access vlan 2
interface FastEthernet1/0/11
interface FastEthernet1/0/12
--More-- spanning-tree portfast
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
interface FastEthernet1/0/18
interface FastEthernet1/0/19
--More-- interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
switchport access vlan 3
interface FastEthernet1/0/23
duplex half
interface FastEthernet1/0/24
interface GigabitEthernet1/0/1
--More-- !
interface GigabitEthernet1/0/2
interface Vlan1
ip address 192.168.0.244 255.255.255.0
interface Vlan2
ip address 20.20.20.1 255.255.255.0
ip policy route-map pbr
interface Vlan3
ip address 172.31.131.1 255.255.255.240
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.2
ip http server
access-list 10 permit 20.20.20.0 0.0.0.255
route-map pbr permit 10
match ip address 10
set ip next-hop 172.31.131.14
--More-- !
control-plane
line con 0
line vty 0 4
no login
line vty 5 15
no login
end
I want to ping 20.20.20.1 from my pc with 20.20.20.2 ip address ,& ping 172.31.131.14 or 172.31.131.14 ,but I can't .if my pc be in vlan 2 with 20.20.20.1 default gateway, I should to ping 20.20.20.1 but
I can't.what's the problem. if I want to route vlan 2 to next-hop 172.31.131.14
,I can't never access to vlan 1 or vlan 3 networks despite the fact that with enaqble ip routing in 3750 i expect that I can run intervlan routing.
could you pls guid me.
thanks
289
