SPAN More Than 1 Vlan for Received/Sent Traffic
Is it possible to have mirror traffic that has been received/sent for more than one VLAN on more than one source port and/or destination port on the same switch for 5500 v5.5.5 and on 6509 Native IOS?
Also, I believe you can SPAN a trunk, but can you SPAN a ISL trunk, but somehow limit those VLANS within the Trunk for port monitoring purposes?I
If you know any information, that would be great.
Re: SPAN More Than 1 Vlan for Received/Sent Traffic
You cannot have multiple destination ports for the same source port/VLAN.
Regarding your second question, you can use the filter option to limit VLANs(not available in CAT5k though)
http://www.cisco.com/warp/public/473/41.html
http://cio.cisco.com/univercd/cc/td/doc/product/lan/cat6000/12_1e/swconfig/span.htm#xtocid13
Thanks for responding! What I meant to ask was: Can you have one source and one destination for one vlan and another source/destination for a different VLAN on the same switch? I need to monitor more than one VLAN, but currently we have only one switch for a 5500 and 6509 at two separate sites.
As a sidenote, we are not utlizing trunk ports at the time being since we have ony one switch.
Thanks in advance!
Yes you can span multiple ports...
Use the span 1 2/4 create (the create allows it to add another span session)...
JIm
101
