Community Member
SPAN problem in cisco 6509 with sup 720
I have cisco 6509 switch with 720 sup.i insatalled 5 10/100BaseTX Ethernet(WS-X6148-RJ-45) but
when i configure span i get below error
set span 1/11 3/14 both inpkts enable learning enable multicast enable create
Error---Port with a Private Port in the same ASIC can't be made span destination.
I need to create span for particular port for troubleshooting.
Please let me know if any atternate way for creation of span & monitor the port.
Moorthy
Silver
Re: SPAN problem in cisco 6509 with sup 720
Hello Moorthy,
Use another destination port that is not bound to the same ASIC. The selected port 3/14 is member of the same COIL ASIC as a trunk, SPAN or PVLAN port.
Due to hardware limitations, Catalyst 650010/100-Mbps modules restrict the configuration of an isolated or community VLAN port when one port within the same COIL ASIC is a trunk, a SPAN destination, or a promiscuous PVLAN port.
The COIL ASIC controls 12 ports on most modules and 48 ports on the Catalyst 6548 module.
--Leon
* Please rate posts.
Community Member
The COIL ASIC controls 12 ports on most modules and 48 ports on the Catalyst 6548 module.I tiried to configure on different module also but it is same error on all modules.
Please find Sh ver of the switch.
WS-C6509 Software, Version NmpSW: 8.2(1)
Copyright (c) 1995-2003 by Cisco Systems
NMP S/W compiled on Dec 18 2003, 17:10:53
System Bootstrap Version: 7.7(1)
System Web Interface Version: Engine Version: 5.3.4 ADP Device: Cat6000 ADP Vers
ion: 5.0 ADK: 40
System Boot Image File is 'bootflash:cat6000-sup720cvk8.8-2-1.bin'
System Configuration register is 0x2102
Hardware Version: 3.0 Model: WS-C6509 Serial #: SAL0751QQWW
PS1 Module: WS-CAC-2500W Serial #: ART0803E0CQ
PS2 Module: WS-CAC-2500W Serial #: ART0748E0K7
Mod Port Model Serial # Versions
1 48 WS-X6148-RJ-45 SAL0730HFNB Hw : 1.3
Fw : 5.4(2)
Sw : 8.2(1)
2 48 WS-X6348-RJ-45 SAL06468GMR Hw : 6.2
Fw : 5.4(2)
Sw : 8.2(1)
3 48 WS-X6148-RJ-45 SAL0738LQAC Hw : 1.3
Fw : 5.4(2)
Sw : 8.2(1)
4 48 WS-X6148-RJ-45 SAL0749Q6YW Hw : 1.3
Fw : 5.4(2)
Sw : 8.2(1)
5 2 WS-SUP720-BASE SAD074200Y1 Hw : 2.3
Fw : 7.7(1)
Fw1: 8.2(1)
Sw : 8.2(1)
Sw1: 8.2(1)
6 2 WS-SUP720-BASE SAD074708DJ Hw : 2.3
Fw : 7.7(1)
Fw1: 8.2(1)
Sw : 8.2(1)
Sw1: 8.2(1)
7 48 WS-X6148-RJ-45 SAL0749Q6W5 Hw : 1.3
Fw : 5.4(2)
Sw : 8.2(1)
9 16 WS-X6516A-GBIC SAL0801RWBJ Hw : 3.0
Fw : 7.2(1)
Sw : 8.2(1)
15 1 WS-SUP720 SAD074203AN Hw : 1.5
Fw : 12.2(17a)SX1
Sw : 12.2(17a)SX1
16 1 WS-SUP720 SAD074708YX Hw : 1.5
Fw : 12.2(17a)SX1
Sw : 12.2(17a)SX1
Each every configuration i tried but still i am not able to do it.I had successfully configured on another switch same with same configureation.Please suggest
Hi Moorty,
I would suggest to use some other module to setup the detsination port. You can use any other module and try using any port from 25-48.
HTH, Please rate if it does.
-amit singh
Community Member
Dear Amit,
Please find the below error.Well i had tried on another switch with same IOS & hardware it is working.
6509> (enable) set span 1/2 1/26 create
6509> (enable) set span 1/2 2/2 create
6509> (enable) set span 1/2 2/48 create
6509> (enable) set span 1/2 3/14 create
6509> (enable) set span 3/14 1/2 create
Moorthy.
345
