SPAN with different speed settings
What happens if you're doing SPAN with a source Gigaethernet port and a destination 10/100 port? Will the buffers fill and packets started to be droped?
What if you're monitoring a trunk port? Do packets arrive ISL or DOT1Q encapsulated although your destination port is an access port
What if you're monitoring a trunk and a non-trunk port simultaneously?
1 ACCEPTED SOLUTION
Re: SPAN with different speed settings
AFAIK:
Q:What happens if you're doing SPAN with a source Gigaethernet port and a destination 10/100 port? Will the buffers fill and packets started to be droped?
A:Yes, if there is a heavy traffic on the source port, buffers will overflow a frames will be droped. Similar situation is when you span VLAN to a port.
Q:What if you're monitoring a trunk port? Do packets arrive ISL or DOT1Q encapsulated although your destination port is an access port
A: Yes, frames are mirrored encapsulated (tagged) even while the target port is an access one.
Q:What if you're monitoring a trunk and a non-trunk port simultaneously?
A: The same as previous question. Tagged frames are mirrored tagged, untagged remain untagged.
Milan
AFAIK:
Milan
Thanks Milan
138
