Community Member
spanning tree problem - BPDU's
hi,
Have a look at attachment,there is a 2950 24 port switch , which is connected to 8274 ibm core switch via ethernet.The 2950 has two fibre modules connected to 4507 switch with hsrp and etherchannel configured.
The 2950 switch ethernet link connected to 8274 ibm core switch is
fluctuating. at rare cases the ethernet led truns amber and link goes down for few seconds.
On observing the 2950 switch, it was found that there is no issue
with the hardware , It is a BPDU problem , where BPDU packets are
being generated by both data centre switch and IBM core switch. Any
one of the BPDU has to be blocked inorder to avoid the link failure.
The following commands were tested in the cisco 2950 switch .
1. Spanning-tree Port fast has been enabled.(for testing purpose)
2. Spanning-tree portfast bpdufilter default.
3. Making fastethernet 0/1 as trunklink.
4. Changing Spanningtree priority value.
5. Enabling Spanningtree gaurd root.
Note :
The Ethernet port of 8274 IBM core switch connecting 2950 switch has to be
made as trunk, since it is an uplink to 2950 switch..it is not yet checked as we dont have access to ibm switch.
it is sure that only configuration changes has to be done at 2950 side, since hardware has been replaced last before week and old conf is missing, earlier it was working setup.
i have pasted the error message,configuration details of 2950 switch.
Error message
interface GigabitEthernet0/1
--More--
1w3d: %SPANTREE-7-RECV_1Q_NON_TRUNK: Received 802.1Q BPDU on non trunk
FastEther
net0/1 VLAN1.
1w3d: %SPANTREE-7-BLOCK_PORT_TYPE: Blocking FastEthernet0/1 on VLAN0001.
Inconsi
stent port type.
1w3d: %SPANTREE-2-UNBLOCK_CONSIST_PORT: Unblocking FastEthernet0/1 on
VLAN0001.
Port consistency switchport mode trunk
regards
Babu
Community Member
Re: spanning tree problem - BPDU's
configuration of 2950 switch.
Switch#sh run
Building configuration...
Current configuration : 1658 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
no ip address
interface FastEthernet0/2
no ip address
interface FastEthernet0/3
no ip address
interface FastEthernet0/4
no ip address
interface FastEthernet0/5
no ip address
interface FastEthernet0/6
no ip address
interface FastEthernet0/7
no ip address
interface FastEthernet0/8
no ip address
interface FastEthernet0/9
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface FastEthernet0/13
no ip address
interface FastEthernet0/14
no ip address
interface FastEthernet0/15
no ip address
interface FastEthernet0/16
no ip address
interface FastEthernet0/17
no ip address
interface FastEthernet0/18
no ip address
interface FastEthernet0/19
no ip address
interface FastEthernet0/20
no ip address
interface FastEthernet0/21
no ip address
interface FastEthernet0/22
no ip address
interface FastEthernet0/23
no ip address
interface FastEthernet0/24
no ip address
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
no ip address
no ip route-cache
no shutdown
ip default-gateway 192.168.27.244
ip http server
line con 0
line vty 0
password cisco
login
line vty 1 4
login
line vty 5 15
end
Switch# sh int fa0/1
FastEthernet0/1 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 000d.bce2.d981 (bia 000d.bce2.d981)
MTU 1500 bytes, BW 100000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is off
Last input 00:00:00, output 00:00:02, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
5 minute ouxtput rate 0 bits/sec, 0 packets/sec
22080908 packets input, 3195162754 bytes, 0 no buffer
Received 14136375 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ig
Silver
Hi Babu,
Just go thro. the following link explaining various reasons for link fluctuation due to stp inconsistencies,
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00801d11a0.shtml
I think your ibm switch port may be in 802.1Q trunk mode. Pls. chk. If else, see you case come under which category in that link.
Hope it will help
Error Message: SPANTREE-7-RECV-1Q-NON-TRUNK: Received 802.1Q BPDU on non trunk
[chars] [chars].
Note: This message applies to Catalyst 3550, 2955, 2950, and 2940 switches.
Explanation: An SSTP bridge protocol data units (BPDU) was received on the listed interface, which is not an operational trunking interface. The first [chars] is the port name, and the second [chars] is the VLAN name.
Recommended Action: Verify that the configuration and operational state of the listed interface and that of the interface to which it is connected are in the same mode (access or trunk). If the mode is trunk, verify that both interfaces have the same encapsulation (none, ISL, or 802.1Q). When these parameters are consistent, spanning tree automatically unblocks the interface.
Looks like the IBM is sending DTP in which the fa0/1 becomes trunk and switch unblock the port and removes the inconsistency. Follow the recommendation above.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12122ea7/smg/msg_desc.htm
2644
