08-20-2003 11:37 PM - edited 03-02-2019 09:46 AM
Our network is getting hit on a specific port. Is there any way (a debug?) I can get an output of addresses hitting that port, and also can I write the output to a file or TFTP server?
08-20-2003 11:45 PM
enable on the interfaces, where this traffic can possibly pass through, Netflow caching...
command is ip route-cache flow.
Once you do this, give the command,
show ip cache flow
This will list all traffic including source / destination ips and src / dst port numbers.
Note that port numbers are in hex.
Good luck!
08-21-2003 12:22 AM
can I actually log that to a file though?
08-21-2003 07:10 AM
You can definitely copy the output and paste it. I guess, thats the only thing you can do.
