Webcast-Catalyst9k
split horizon on vlan interface
I found some strange problem. Topo like this:
3550a-----trunk------3550b
10.0.30.251
vlan 230
10.0.30.249
7507---l0.0.64.0/23
3550b#sh ip eigrp to all
IP-EIGRP Topology Table for AS(10)/ID(10.0.97.2)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
P 10.0.64.0/23, 1 successors, FD is 130816, serno 68
via 10.0.30.249 (130816/128256), Vlan230
via 10.0.30.251 (131328/131072), Vlan230
I think 7507 send update to 3550a and 3550b, Then 3550a send same update to 3550b through trunk port. So split horizon is in affect on the layer2 port NOT layer 3 interface?
Re: split horizon on vlan interface
This is while EIGRP does not know about the physical topology.
To EIGRP the network looks like:
3550A -- vlan230 -- 3550B
-- some other vlans -------
7507
So it is normal to see two possible routes to the 7507 from vlan230.
Goodluck
Sorry but I see that my diagram was truncated. What I mean is that both 3550's have connection to all other vlans. The exclamation marks were on the left and right ends. The spaces inbetween were appearently ingnored and now it looks a bit confusing.
thank for your reply.
My topo is this:
eigrp running on interface vlan230,vlan99 of 3550a and 3550b, int f4/0/0 (is vlan230) of 7507.
I guess the flowchart is like this:
1.7507 send 10.0.64.0/23 update to 3550a and 3550b
so 3550b has the route which next hop is 7507.
2.3550b send 10.0.64.0/23 update to 3550b through vlan 99
3.Then 3550a send 10.0.64.0/23 update to 3550b and 7507 through vlan230.
So my question is 3550a get the route from vlan 230,if split horizen is in affect,why 3550a send the same route to vlan230(although next hop is different).
When 3550b get the route from vlan 230,Does it send the route to vlan 99 again,and so on,so there is routing loop.Oh,I know this is not correct ,But I am confused with some base concept
3550a-----trunk(vlan230,vlan99)------3550b
10.0.30.251
vlan 230
10.0.30.249
7507---l0.0.64.0/23
I think split horizon rule is not applicable for the above case.
Because Split horizon rule states "A route canot be updated on an interface from which it is learned". In the above case 3550a is learning route via vlan99 from 3550b with different metric. The same would be advertised on VLAN230
The above is not a continuous process, because 3550b always advertises the route with best metric in its routing table via VLAN 99. Here DUAL algorithm takes care of loop prevention if you see topology table you can see only one successor because Advertised Distance of 3550a is more than Feasible Distance of the corresponding route.
I never used that command "sh ip eigrp topology all", if you use "sh ip eigrp topology", you can see only one entry in topology database.
Please correct me if I am wrong.
thank you!
Maybe I understand.
when I show route on 7507,I can see following:
Can I make 3550a not send this update to 7507 ? Does this display correct?
7507#sh ip eigrp to all
IP-EIGRP Topology Table for AS(10)/ID(10.0.28.1)
P 10.0.64.0/23, 1 successors, FD is 128256, serno 79
via Summary (128256/0), Null0
via 10.0.30.251 (156672/131072), FastEthernet4/0/0
EIGRP updates are multicasts to all routers on the subnet (read vlan).
They are all aware of eachother. Combining all updates they build a topology of the network as it looks on layer 3. A trunk link corresponds to multiple segments when you look at it like this.
Hope this helps to clarify.
Leo
thanks again,And another summary question :-D
when I do summary on interface,AD is 5.Why I show this route from 3550b,it display [90/130816] ?
Is the AD which set on ip summary-address in affect ?
7507#sh run int f4/0/0
interface FastEthernet4/0/0
ip address 10.0.30.249 255.255.255.0
ip summary-address eigrp 10 10.0.64.0 255.255.254.0 5
duplex auto
speed auto
bridge-group 4
bridge-group 4 spanning-disabled
end
3550b#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is 10.0.27.1 to network 0.0.0.0
10.0.0.0/8 is variably subnetted, 19 subnets, 5 masks
D 10.0.64.0/23 [90/130816] via 10.0.30.249, 03:02:33, Vlan230
Can you try this?
Please modify the mask for summery address from 23 to 18. Since your network number is 10.0.64.0 it does not harm you anyway.
Like this
ip summary-address eigrp 10 10.0.64.0 255.255.192.0 5
duplex auto
speed auto
bridge-group 4
end
Please try the above.
I tried it.But result is same. Even if I modify the AD from 5 to any,it doesn't have any in affect. Maybe IOS does not support this function?
724
