02-06-2003 05:37 AM - edited 03-02-2019 04:51 AM
I have a DS3 circuit between two ABRs. Presently the circuit is in area 1 and a virtual link is configured between the two for proper routing. I am changing this area to a NSSA area. In order to maintain optimal routing I now need two(2) circuits between these ABRs one in area 1 the other in area 0. I do not want a $econd DS3 circuit. Is it possible to use a mux/demux at each end to split this existing DS3 circuit into two separate circuits at the routers?
Thanks in advance for any info,
Jim Coffey
02-06-2003 06:13 AM
Hi Jim again
well i guess if u make two subinterfaces on this DS3 circuit with two different IP addresses and if u put each subinterface relating to n OSPF area..it should work without another DS3 or a MUX/DMUX
hope it works
02-06-2003 06:22 AM
Good thought, I hadn't thought of that. BUT I do not think this will work since OSPF adjacencies will only be formed over primary networks and not secondary networks.
02-06-2003 08:16 AM
it is not a secondary IP address..i think he will treat it as a normal interface..as it is having its own IP , and it is not a secondary ip on the same interface.
try it , or if u r not in a hurry..i can test it for u :)
my lab is still alive
02-06-2003 07:13 AM
How about using a GRE tunnel between a loopback interface on each router, route the tunnel over the DS3 and place it in OSPF Area 1 and the DS3 itself in OSPF Area 0
02-06-2003 09:07 AM
The GRE tunnel seems a little complicated to me and I believe in KISS (keeping it simple) :-)
I am not knowledgable of how sub-interfaces function or their configuration :-( . This DS3 is a single physical point-to-point leased line. Will sub-interfaces take a single physical line and treat it as two logical (virtual) interfaces? How will OSPF treat this? I guess I need to study up on sub-interfaces etc. ;-)
If Mohamed can test this in his lab it would be helpful (Thanks, Mohamed.)
Maybe we'll all learn something.
Jim Coffey
