Community Member
Stacking issues -> STP
Hi guyz, i'm wondering about the stp issues for stacking. i got 2 switch and they are stacked, and i also pull a UTP cable to connect this 2 swtich as a uplink trunk port.
1)Am i goin to face STP looping issues in this scenario?
2)theoretically, STACKING is logically combines 2 switches to form a logical switch. So ther should'n have looping issue in the scenario, am i rite ?
Thanks in millions
William
Super Bronze
Re: Stacking issues -> STP
It depends a lot on what stacking technology you are using...
If you have 3750s with the stackwise connectors, then you effectively have a single switch... You also wouldn't need the extra UTP cable as the stackwise connectors form a redundant ring topology...
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Community Member
but what if customer accidentally connect a a extra UTP cable ?
Super Bronze
In that case the switch will see the BPDUs (it's own BPDUs actually) and will then put the port into spanning-tree blocked state to break the loop.
Aaron
162
