Standard ACL and wild card mask
If The following commands were entered on a router:
Router(config)# access-list 2 deny 172.16.5.24
Router(config)# access-list 2 permit any
What can be concluded about this set of commands?,,,(i.e wild card mask has not been used with deny statement),,,Does a router accept it ? I do not router right now to do practical test
Purple
Re: Standard ACL and wild card mask
The effect of this access-list would be to deny just the host 172.16.5.24 and to permit everything else. The router would accept this command line.
The lack of a wildcard in this case means that the IP address is a host address. The following access-list statements result in identical behaviour, for example:
access-list 1 permit ip 172.16.5.24
access-list 1 permit ip 172.16.5.24 0.0.0.0
access-list 1 permit ip host 172.16.5.24
Hope that helps - pls rate the post if it does.
Paresh.
distance 140 0.0.0.0 255.255.255.255 9
access-list 9 permit 197.135.20.0
access-list 9 permit 197.135.24.0
access-list 9 permit 197.135.27.0
This is partial of the output ,,,,can we omit the wildcard mask with the network address as well, when we use standard ACL ?
Purple
You certainly omit the wildcard mask when using standard ACLs, and it will default to 0.0.0.0...
Hope that helps.
Pls remember to rate posts.
Paresh.
398
