Standard routing and policy routing?
Hi there!
Is it possible to set up ip policy routing on an interface (using the route-map command matching an ACL and setting the next hop) and use the "standard" routing table when there are no packets matching the ACL?
Or let's put it this way:
If no match is found in the route-map what happens to the packet?
Thank's! :)
Jorge B.
1 ACCEPTED SOLUTION
Bronze
Re: Standard routing and policy routing?
If there is no match, the packet gets routed according to what exists in the routing table.
-HTH
1 REPLY
Bronze
-HTH
83
