start-problems with a 3640
hi,
i have upgraded my 3640 router to 32mb flash.
since there is no valid image in the new flash, i want that the router should start from the pcmcia-slot0 and the i am able to copy the file from slot0 to flash.
i thought so - but it does not work!
rommon 2 > dev
Devices in device table:
id name
flash: flash
slot0: PCMCIA slot 0
slot1: PCMCIA slot 1
eprom: eprom
rommon 3 > dir slot0:
File size Checksum File name
19265320 bytes (0x125f728) 0xd5f0 c3640-js-mz.123-3.bin
So the router says there is ios image in slot0 !
but when i do the following:
rommon 4 > boot slot0:c3640-js-mz.123-3.bin
program load complete, entry point: 0x80008000, size: 0x125f5e4
Self decompressing the image :
Error : Uncompression of the image failed.
invalid compressed data--format violated
Error : zip decompress failed
*** System received a Software forced crash ***
signal= 0x17, code= 0x7, context= 0x0
PC = 0x800080d4, Cause = 0x20, Status Reg = 0x3041f003
System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
C3600 processor with 131072 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
program load complete, entry point: 0x80008000, size: 0xc80080
PCMCIA Slot1: No Card Present
rommon 1 >
PLEASE HELP !
Thanky you
  • Other Network Infrastructure Subjects
1 REPLY
Re: start-problems with a 3640
Hi! I think maybe you should firstly consider two things:
1. Can you use the pcmcia to boot another 3640 router successfully? Cos you can see the Error : Uncompression of the image failed. invalid compressed data--format violated.
2. Insert the pcmcia to slot1 and then boot the router from slot1, check the result.
If both failed, you have to find another pcmcia with correct ios or use xmodem to transfer new ios.
Hope this helps. Thanks.
104
