startup won't load at boot
I just got a used 2514 router to use in a test environment, so this is no big deal. But it is annoying.
When I reload or restart the router, the startup-config does not load.
Since I have previously saved any changes by copying run start, all I have to do is to copy start run.
Is this likely a configuration issue, or perhaps the reason this router was being sold dirt cheap?
Otherwise it seems to function OK.
1 REPLY
Re: startup won't load at boot
Please check if the config register contains the value: 0x2102.
It might be at 0x2142 or so. With that setting the startup config is ignored. Restore it to the correct value and you might be in working order.
Leo
107
