Community Member
Static NAT- how many. Possible to NAT two complete networks
Is there a limitation on number of static NAT you can put on a router?
Can you NAT a whole network range to another network range (so you don't have to type 50 static nat's)?
1 REPLY
Bronze
Re: Static NAT- how many. Possible to NAT two complete networks
Any limitation is probably relative to the amount of available memory. The 'ip nat inside source static network' command comes in handy for NAT'ing network ranges.
172
