static route and eigrp two questions
first:
I use static float route to use backup interface,and destination are two net: 21.0.0.0,22.0.0.0 but when master interface serial down ,only the net 21.0.0.0 next hop chage to backup interface and net 22.0.0.0 still use default next hop (the master interface,even it is down),why? it is so strange!
config is below:
interface Serial5/0
ip address 22.52.127.6 255.255.255.252
ip access-group 144 in
ip access-group 144 out
encapsulation ppp
ip route 21.52.64.0 255.255.224.0 22.52.124.25 80
ip route 21.52.64.0 255.255.255.0 21.52.127.5
ip route 22.52.64.0 255.255.224.0 22.52.124.25 80
ip route 22.52.64.0 255.255.255.0 21.52.127.5
#show ip interface brief
Serial5/0 22.52.127.6 YES NVRAM down down
#show ip route
S 21.52.64.0/19 [80/0] via 22.52.124.25
S 22.52.64.0/19 [1/0] via 21.52.124.5
#show version
IOS (tm) 7200 Software (C7200-JS-M), Version 12.1(20)E, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)
The strange happened in all my wan interface! and I have another 7206 with different IOS at work online too,and even have the trouble!!!
second:same router and same config, i use eigrp too, but when i use no auto-summary config why still a summary address in route table???
#show running-config
router eigrp 1
network 21.0.0.0
network 22.0.0.0
network 23.0.0.0
no auto-summary
eigrp log-neighbor-changes
no eigrp log-neighbor-warnings
#show ip route
D 21.52.0.0/17 is a summary, 21:55:13, Null0
any suggest is thankful!!
DAVID
1 REPLY
Re: static route and eigrp two questions
1)
It is not so strange. Your static route only specifies a next hop. As long as the next hop for that static route (in this case 21.52.127.5) is resolvable , either via a directly connected route or via any other route, the static route will remain in the routing table.
If you want to make sure that the static route is removed after the interface goes down, use the following syntax:
ip route 21.52.64.0 255.255.255.0 se5/0
ip route 22.52.64.0 255.255.255.0 se5/0
2) The summary installed by Eigrp in the routing table is not due to auto summarization (not on majornet boundary) but to manual summarization. Check your configuration for the following statement on one of the interfaces on this router:
ip summary-address eigrp 1 21.52.0.0 255.255.128.0 5
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
164
