Community Member
static route and eigrp two questions
first:
I use static float route to use backup interface,and destination are two net: 21.0.0.0,22.0.0.0 but when master interface serial down ,only the net 21.0.0.0 next hop chage to backup interface and net 22.0.0.0 still use default next hop (the master interface,even it is down),why? it is so strange!
config is below:
interface Serial5/0
ip address 22.52.127.6 255.255.255.252
ip access-group 144 in
ip access-group 144 out
encapsulation ppp
ip route 21.52.64.0 255.255.224.0 22.52.124.25 80
ip route 21.52.64.0 255.255.255.0 21.52.127.5
ip route 22.52.64.0 255.255.224.0 22.52.124.25 80
ip route 22.52.64.0 255.255.255.0 21.52.127.5
#show ip interface brief
Serial5/0 22.52.127.6 YES NVRAM down down
#show ip route
S 21.52.64.0/19 [80/0] via 22.52.124.25
S 22.52.64.0/19 [1/0] via 21.52.124.5
#show version
IOS (tm) 7200 Software (C7200-JS-M), Version 12.1(20)E, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)
The strange happened in all my wan interface! and I have another 7206 with different IOS at work online too,and even have the trouble!!!
second:same router and same config, i use eigrp too, but when i use no auto-summary config why still a summary address in route table???
#show running-config
router eigrp 1
network 21.0.0.0
network 22.0.0.0
network 23.0.0.0
no auto-summary
eigrp log-neighbor-changes
no eigrp log-neighbor-warnings
#show ip route
D 21.52.0.0/17 is a summary, 21:55:13, Null0
any suggest is thankful!!
DAVID
1 ACCEPTED SOLUTION
Gold
Re: static route and eigrp two questions
What you have is:
#1 ip route 22.52.64.0 255.255.255.0 21.52.127.5
-- This one installs because the next hop is reachable through 22.52.124.25, which is outside the range of the destination addresses themselves.
#2 ip route 22.52.64.0 255.255.224.0 22.52.124.25 80
-- This one doesn't install because the lower admin distance route, #1, is installed, instead.
#3 ip route 21.52.64.0 255.255.255.0 21.52.127.5
-- This one doesn't install, because the next hop is only reachable via:
Which is a summary containing the space of the route itself--and the summary is built on the static route. In other words, it's a recursion loop. x/24 is used to build x/17, and the only way to reach the next hop for x/24 is through the summary to x/17, which is built from x/24 itself. We won't install this route.
#4 ip route 21.52.64.0 255.255.224.0 22.52.124.25 80
This one installs because, again, the next hop is reachable through some address outside the range of the destination address itself--the other static that's still installed.
Russ.W
Gold
Can do a show ip route 21.52.124.5 when the first interface is down? You don't happen to have a command ip summary-address eigrp configured anyplace on the router, do you?
Russ.W
Community Member
THANKS
as message before,i have do "no auto-summary" in my eigrp ,but i have some summary address in some interface ,is it the reason?
#show running inter se4/0
interface Serial4/0
bandwidth 2048
ip address 21.48.254.117 255.255.255.252 encapsulation ppp
ip summary-address eigrp 1 22.52.0.0 255.255.128.0 5
ip summary-address eigrp 1 21.52.0.0 255.255.128.0 5
DAVID
Gold
Yes, this is a manual summary, and isn't impacted by the auto-summary command.
Russ.W
Community Member
well ,thanks!
but why this summary route is only effect on 22.0.0.0/8 address and not on 21.0.0.0/8 address as i
refer before!
DAVID
This question would be better answer by a "sh ip route" while the serial interface is down. In any case did you try pointing the static route to the serial interface instead of the next-hop ip address as follow:
ip route serial2
This should take care of it.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Sorry, I see you already had the "sh ip route"in there.
What I would still suggest is.
1) Change your static as follow:
ip route 21.52.64.0 255.255.255.0 Serial5/0
ip route 22.52.64.0 255.255.255.0 Serial5/0
This will ensure that as the interface goes down the static routes will be removed from the routing table.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
By the way, you should probably configure the physical interface with the floating static as well.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Gold
Because 21.52.64.0 falls within the summary range--we won't recurse onto the summary for the next hop towards the summary itself. When the main route fails, we will fall back on the summary as the path to the next hop for the 22 network, since it doesn't fall within the summary, but when we attempt to fall back on the summary for 21.52.64.0, we find this address space is a part of the summary, so that fails. Then, the second static is installed, and we fall back on that.
Russ.W
Community Member
Thank,
but I do not really understand Russ.W's answer-"we won't recurse onto the summary for the next hop towards the summary itself"
have some document about it?
DAVID
Gold
What you have is:
Russ.W
Community Member
OK,I SEE!
Thanks very much!
Community Member
I think that #2 is a floating static for #1. They are two independent/different routes, since they have different masks. Therefore with both links up #1 and #2 should be in the main routing table. With the serial down, then #1 should go down. To have a true floating static the network and mask should be identical.
Ian
130
