Static routes pointing to other routers over a LAN
I have two routers (R1 and R2) connected to the same LAN. From R1, I need to get to a subnet that is behind R2. If I put a static route in R1 like:
ip route 11.10.0.0 255.255.0.0 10.0.0.2
where 11.10.0.0 is the subnet I want to get to
10.0.0.2 is the LAN port IP address of R2
(FYI: The LAN port IP address of R1 is 10.0.0.1)
Will this static route be removed from the routing table of R1 if R2 or the LAN port of R2 fails?
1 ACCEPTED SOLUTION
Re: Static routes pointing to other routers over a LAN
No, it will never be removed from the configuration. It will only be removed from the routing table if the R1 interface fails or is admin down. As soon as the interface is restored it will be inserted back into the routing table. It R2 fails, then you have a problem. Without dynamic routing R1 will always send, or attmept to send, all packets destined for 11.10.0.0 to R2. If you want to have alternate paths to 11.10.0.0 you should look into dynamic routing. Does this help?
Kevin
1 REPLY
Kevin
83
