You can use either one of them. Advantage of using a dynamic protocol is that its administration hassle free...But remember RIP has a hop limit of 15. .In your case, since the network is real small, you can use static routing.
Advantages of using static routing here, is that, the wan bandwidth wont be utilized for sending frequent RIP updates.
If you are planning to use dynamic routing protocol instead, try using EIGRP instead of RIP. Or if you are stuck with RIP, then use, "ip rip triggered" command, on the wan interfaces, to force only triggered updates to be sent over the wan, instead of sending updates periodically.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
