08-07-2002 01:47 PM - edited 03-02-2019 12:31 AM
Hi, I have a problem when dialing from a BRI interface to the PRI interface. I have tested it by pinging to 192.168.10.3 (this is the dialer interface of the PRI). Who can help me?
by pinging to 192.168.10.3 It seems that a link is build up, but by viewing the log, the link is hang up. There won't be any reply's on that ping.
Question: The PRI interface is also configured to handle incoming voice modems, must I also deleted the "ísdn incoming-voice modem"? If I delete it, I think that other users cant call in anymore. Or is it possible that the PRI interface can handle "incoming-voice modem and ISDN calls?
config of the BRI router:
Cisco2651#sh runn
Building configuration...
Current configuration : 1626 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Cisco2651
enable password 7 xxxxxxx
ip subnet-zero
ip cef
no ip domain-lookup
ipx routing 1897.7854.6c4e
isdn switch-type basic-net3
interface FastEthernet0/0
description connected to EthernetLAN
ip address 172.16.1.2 255.255.0.0
duplex auto
speed auto
ipx network 10 encapsulation SAP
interface BRI0/0
ip address 192.168.10.2 255.255.255.0
encapsulation ppp
dialer idle-timeout 30
dialer map ip 192.168.10.3 name CiscoRAS broadcast xxxxx
dialer watch-group 2
dialer-group 3
ppp authentication pap
ppp pap sent-username ISDNBACKUP password 7 Wireless
interface FastEthernet0/1
description connected to EthernetLAN_1
ip address 172.17.1.2 255.255.0.0
duplex auto
speed auto
ipx network 11 encapsulation SAP
router eigrp 100
network 11.0.0.0
network 172.16.0.0
network 172.17.0.0
network 192.168.10.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip forward-protocol udp 6502
ip route 0.0.0.0 0.0.0.0 172.16.1.1
ip route 172.17.0.0 255.255.0.0 FastEthernet0/1
ip route 192.168.88.0 255.255.255.0 FastEthernet0/1
ip http server
ip pim bidir-enable
access-list 103 deny eigrp any any
access-list 103 permit ip any any
dialer watch-list 2 ip 11.1.1.1 255.0.0.0
dialer-list 3 protocol ip list 103
configuration PRI router
CiscoRAS#sh runn
Current configuration : 5135 bytes
version 12.1
service timestamps debug datetime
service timestamps log datetime
hostname CiscoRAS
logging buffered 4096 debugging
no logging console
enable password 7 095C5B021A0415
username xxxxxxxxxxx
username ISDNBACKUP password 0 Wireless
modem country mica netherlands
ip subnet-zero
isdn switch-type primary-net5
isdn voice-call-failure 0
modemcap entry TAC:MSC=&F&D2S34=18000S40=10S54=456S10=50debugthismodemS71=4
controller E1 1/0
pri-group timeslots 1-31
controller E1 1/1
interface Loopback0
ip address 192.168.100.254 255.255.255.0
interface FastEthernet1/0
ip address 172.16.1.20 255.255.0.0
ip nat outside
no keepalive
duplex auto
speed auto
interface Serial1/0:15
no ip address
encapsulation ppp
dialer pool-member 1
isdn incoming-voice modem
no cdp enable
ppp callback accept
ppp authentication pap ms-chap
interface Group-Async1
no ip address
encapsulation ppp
dialer in-band
dialer pool-member 2
async mode dedicated
ppp callback accept
group-range 1 30
interface Dialer0
ip unnumbered Loopback0
ip nat inside
encapsulation ppp
dialer pool 1
dialer idle-timeout 300
dialer enable-timeout 5
dialer redial interval 5 attempts 1
dialer-group 1
peer default ip address pool inbpool
ppp callback accept
ppp authentication pap callin
ppp chap refuse
interface Dialer1
ip address 11.1.1.1 255.0.0.0 secondary
ip address 192.168.10.3 255.255.255.0
encapsulation ppp
dialer pool 1
dialer-group 3
interface Dialer60
ip nat inside
encapsulation ppp
dialer pool 2
dialer-group 1
ppp callback accept
ppp chap refuse
router eigrp 100
network 11.0.0.0
network 172.16.0.0
auto-summary
ip local pool inbpool 192.168.100.1 192.168.100.100
ip nat inside source list 101 interface FastEthernet1/0 overload
ip classless
ip route 192.168.100.0 255.255.255.0 FastEthernet1/0
no ip http server
access-list 101 permit ip 192.168.100.0 0.0.0.255 any
dialer-list 1 protocol ip permit
08-08-2002 09:05 AM
Since you are using a dialer-profiles on receiving router to terminate the call based on username of the dial in router, you need to enter "dialer remote-name ISDNBACKUP" under the dialer interface on which you want to terminate the call (may be under interface Dialer1 )..So in other wards, you need to create dialer interface for each user with that "dialer remote-name xxx" command.
OR
you can use lagacy config..means one interface for all isdn users instead of seperate interface for each user as documented in a following url with sample config
http://www.cisco.com/warp/public/793/access_dial/5300.html
For async calls, you don't need "dialer pool-member 2 " under interface group-async 1..take that out and just add following two commands
dialer-group 1
Now above url does talk about that too.
