Webcast-Catalyst9k
Stop incoming ICMP ON Serial0
I have 1603R with 12.0 IOS. I want to stop incoming ICMP on the router
This is what i Have used.
access-list 101 deny icmp any any
But to my surprise i still c icmp packets reaching my firewall.
What I want is i should be able to ping others but other should be not be able to ping or use any kind of icmp on me...
Regds
RamP
Re: Stop incoming ICMP ON Serial0
Applying the acl to an interface, as in:
int s0/0
ip access-group 101 in
will deny all inbound icmp on Serial 0/0.
To block inbound ICMP but allow ICMP replies your acl should look like this:
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any source-quench
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 permit ip any any
This allows all the ICMP returns to you, denies ICMP inbound and the last line negates the implied deny all that is at the end of all access lists.
After creating the access-list you then need to apply it to the serial interface. Go to interface configuration mode and apply the following:
access-class 101 in
That's all ther is to it.
144
