Community Member
stopping a process on AS5300
I have an AS5300 having the following CHARACTERISTICS:
"System image file is "flash:c5300-jk8s-mz_122-5.bin"
cisco AS5300 (R4K) processor (revision A.32) with 131072K/16384K bytes of memory.
Processor board ID 11816394
R4700 CPU at 150Mhz, Implementation 33, Rev 1.0, 512KB L2 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Primary Rate ISDN software, Version 1.1.
Backplane revision 2
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x30,
Board Hardware Version 1.64, Item Number 800-2544-02,
Board Revision B0, Serial Number 11816394,
PLD/ISP Version 0.0, Manufacture Date 4-Jan-1999.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
4 Channelized E1/PRI port(s)
60 DSP(s), 120 Voice resource(s)
128K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)"
I AM facing a memory Leak problem , I have identified the process that is holding the memory and is not freeding it ; i am not able to do an upgrade due to real time traffic and slow connection , so i am asking if is it possible to stop or kill this process on my device using Cisco CLI(Command Line Interface)?
the designated process is : CCSIP_SPI_CONTRO.
could anyone help?
Re: stopping a process on AS5300
no..there is no way to clear the memory occupied by a process using a command. If router is facing a memory leak, it needs to be reloaded or needs to be loaded with the ios image which has a fix for that.
