Community Member
Storm control and other configuration explanation
Dear Sir,
I was curious how this config works especially the storm-control and ntp server and etc? Mind to share your exprience and explain each of the line?
Thanks.
Your effort are greatly appreciated a lots.! Please explain the attached configuration.
Re: Storm control and other configuration explanation
Use this link to find out what a certain command will do:
http://www-tac/TOOLS/Manual/ios-search.html
Just to quickly expalained the "storm-control broadcast level level[.level]" - Enables broadcast traffic storm control on the interface, configures the traffic storm control level, and applies the traffic storm control level to all traffic storm control modes enabled on the interface.
NTP Server - Just tell the router which NTP master to sync it's clock with.
Community Member
Hi Bosalaza, thank you for your sharing. However the link http://www-tac/TOOLS/Manual/ios-search.html having problems? i can't go in ?
Sorry, that because it's a TAC link and not available externally.
Try this link:
http://www.cisco.com/cgi-bin/Support/Cmdlookup/home.pl
Community Member
hi bosalaza,
i've tried to key in the command storm-control but seem it doesn't helps much. some of the command is not there.
166
