stp (ieee802.1d-1998) tcn_bpdu problem?
i use the topology for test stp tcn_bpdu:
sw_1 (root bridge)
|<port1:root port>
sw_2
|<port2:designated port>
--------pc
sw_2's port1 is root port.
sw_2's port2 is designated port.
0.after the stp tree stable(sw_1 is root bridge),i beging sniffer the port1's ingress&egress package.
1.1min later,i unplug port2.
2.after another 1min,i plug port2.
3.after 3min,i stop sniffer.
from the sniffer file,i fond port1 does't send tcn_bpdu
when i unpluge port2,but it send tcn_bpdu when i pluge
port2.
who can tell me why sw_2 does't send tcn_bpdu when it fond
the port2 down?does it no a topology change?
thans a lots!
1 REPLY
Re: stp (ieee802.1d-1998) tcn_bpdu problem?
The switch will not send topology change notification bpdu's when sw_2 port2 goes down becaucse that port is in a blocked state. Only forwarding state ports cause topology changes. So a loss in connectivity on port 2 sw2 is not considered a topology change. Please refer to the following links for more detailed information:
http://www.cisco.com/warp/public/473/146.html
http://www.cisco.com/warp/public/473/17.html
If this helps please rate my post, thanks.
150
