STP Problem: Switch is seen on blocked link
Hi All
I have following situation:
Two Core Switches 4500 SW_C01 and SW_C02
and some Access Switches SW_A01 ...
The Access Switches are redundant connected to the two Core Switches. From the STP point of view we have a standard triangle situation.
Problem: Pinging the SW_A01 from SW_C02 is not possible.
more details: SW_C01 is root of the stp. On SW_A01, the uplink to the nonroot Coreswitch (which is SW_C02) is blocked (as it should). On the SW_C02 the sh arp tells me that the SW_A01 is connected directly on its own port, what is wrong, because this link is blocked at the other end. So why is the MAC-Address sean here?
Even more details:
The Core Switches are running PVST.
The Access Switch only supports CSTP.
How can I configure the Switches, that the Problem can be solved? Any hints?
Thanks much, Phil
1 REPLY
Re: STP Problem: Switch is seen on blocked link
For STP, what does SW_C02 say about the VLAN/IP Subnet that's not accessible? What does SW_A01 say? Do you have a STP root bridge conflict?
Where's the VLAN interface? You say you can't ping from SW_A01. Do you mean that you can't ping from the switch, or can't ping from a node attached to SW_A01? Do you have a VLAN interface on the switch? Can you ping each VLAN interface IP on each of the three switches?
If you unplug/shutdown the link from SW_A01 to SW_C01, can you ping SW_C02?
Are you doing any VLAN pruning? Do you have trunks properly configured and are you allowing all VLANs across?
201
