STP uplinkfast problem
At this URL:
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_release_note09186a00800aded7.html#wp26366
Cisco document said:
We do not recommend using the UplinkFast feature on switches with more than 20 active VLANs because convergence times might be unacceptably long.
Can anybody explain it ? Why convergence times might be unacceptably long ?
thanks!
1 REPLY
Silver
Re: STP uplinkfast problem
I suspect it may be the sw/hw limitation that only Cisco internal can tell the reason.
If there is such issue, you can consider to use RSTP instead.
Hope this helps.
134
